Old 07-31-2017, 08:30 AM
Nihon_Ni's Avatar
Nihon_Ni Nihon_Ni is offline
Default When to rivet the bottom wing skins
I need some advice from the collective. When I built my RV-8 wings I decided to delay riveting the bottom skins in place because I thought I might need access to the wings later in the build. I'm getting ready to order the engine, and I'm trying to get everything done that can be done before I get it (and the warranty clock starts ticking). So I'm wondering if this is the time to close the wings.
I have conduits for electrical wires installed in each wing. I need to plumb pitot/AOA lines and mount the pitot tube. I bought position and landing lights at OSH and will mount them shortly, but I will delay wiring them until the airplane is at the airport and the wings are on for good.
I'm going to go with Garmin G3X suite, and will use the GSA 28 autopilot servos. I'm thinking the roll servo will go in one of the wings, but is there an alternate location I should consider?
Anything else I should do to the wings before closing them?
Rob
Rob K
RV-8 N884RA under construction
Old 07-31-2017, 09:46 AM
sjhurlbut sjhurlbut is offline
Default You got it
Best location of roll servo is in left wing. Get er done before riveting.
I'd run all wiring through the conduit you have installed. Either a bulkhead connector on the root rib or leave the wires as long as you think they'll need to be - roll up the wire and leave it inside root rib until wings are mounted.
Same with pitot lines.
So in short I'd get EVERYTHING in place before wing skins on - just easier.
Visit and subscribe to Stu's Aircraft Factory on
https://www.youtube.com/channel/UCGQ..._as=subscriber
Steve "Stu"
Cold Lake, Alberta
7A #70015 - C-FZQX - built - sold
7A #71629 - C-FSIS - built - sold across Atlantic
7 #70215 - C-GOJU - flying - sold
7 #70703 - C-GMIY - flying - sold
6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
8 #82842 - C-FSBG - Fastback - built - sold
4 #2723 - building
Old 07-31-2017, 12:32 PM
jcarne's Avatar
jcarne jcarne is offline
Just out of curiosity why is it best in the left wing? I was planning the opposite wing to de-clutter the left a bit.
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
Finish kit almost done
Exempt but gladly paying!
Old 07-31-2017, 01:50 PM
wirejock's Avatar
wirejock wirejock is offline
Default Roll servo
Edit. Ooops. It's the right. Sorry. Don't know what I was thinking.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 07-31-2017, 02:38 PM
Raymo's Avatar
Raymo Raymo is offline
My Dynon roll servo is installed in the right wing, per instructions. Other vendors likely dictate the location.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 07-31-2017, 03:15 PM
Larco's Avatar
Larco Larco is offline
I have installed several Tru Trac A/Ps and all roll servo brackets I received were for the right wing. Much less clutter IMHO. But either wing works just fine. Do what suits you best. The servo mounting brackets are just a mirror image of the other depending on which wing you decide on.
Larry
Old 07-31-2017, 04:41 PM
jcarne's Avatar
Thanks for the replies guys, I'm planning Dynon so looks like right might be the easiest after all according to Raymo. Rob sorry to hijack your thread but I thought this info might help you out as well.
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
Old 08-01-2017, 05:32 AM
Nihon_Ni's Avatar
No worries, this is good discussion!
Rob K
