Old 07-30-2017, 01:23 PM
JF in MI JF in MI is offline
Default ADS-B out WAAS antenna?
After going to OSH this year to look at ADS-B out for my RV-4 I decided to continue waiting (BTW I think every RV that was built was there). I have a used Garmin 696 with a GL-39 antenna so I am doing fine with ADS-B in. A lot of my questions were answered but more were raised along with some confusion. I would like to keep it at or under $1k and simply refuse to put in a system that costs more than 10% of the total value of my plane particularly since I rarely fly in controlled airspace any more. I was leaning toward the Echo UAT or the Beacon 978. What ticks me off is that they tell me (or in some cases wouldn?t tell me) that they need an additional $300 to $500 WAAS antenna. Does anyone know if one of those Globalsat BU353 SiRF Star III USB GPS Receiver Antenna can be wired into these transmitters and if so what is the wiring diagram?
Old 07-30-2017, 02:13 PM
If the device you buy carries a TSO, then you are legally obligated to use the antenna(s) called out in that TSO. If it "meets the rules" per the manufacturer, then you must use the antenna(s) called out by the manufacturer.
GRT is selling the Echo paired with its GPS, antennas included, for a bit more than your budget. But it includes ADSB-in, so maybe you can get a few $$ back by selling your current -in box.
Old 07-30-2017, 02:29 PM
Flying an experimental, I'm a little confused with this TSO thing. I don't think I have one TSO'd device in the entire plane.
Old 07-30-2017, 02:38 PM
RV7A Flyer's Avatar
You must not be flying IFR, then...
Old 07-30-2017, 03:14 PM
...Nor have a transponder....
List of things required for everyone (EAB or not)operating under part 91 to be TSO'd or "meet the operational requirements of the TSO":
transponder
GPS used under IFR
ELT
and, starting in 2020, ADSB-out
BTW, if you "rarely fly in controlled airspace", you must do most of your flying at less than 1200' agl.
Old 07-30-2017, 07:38 PM
Can't; color blind.
Old 07-30-2017, 07:41 PM
transponder
GPS used under IFR
ELT
Pardon my incorrect use of terms. I should have said I fly almost exclusively in class E.
Old 07-30-2017, 07:52 PM
Can't; color blind.
Color blindness does not prevent you from obtaining the instrument rating, nor does it prevent you from flying ifr; it restricts you to daytime.
Old 07-30-2017, 09:28 PM
RV7A Flyer's Avatar
Don't you still have to have ELT?
