You're not trying to seal the threads against pressure, so I would say "no". But you DO want to be able to remove the probe if and when it fails (one of mine just did after 170 hrs.). For that reason, I use nickel anti-seize on those threads. I removed my failed probe today and although tight, it came right out.
(2020 dues paid)
