Old 02-12-2007, 10:21 AM
JimWoo50 JimWoo50 is offline
Default brake question
Is it alright to reverse the position of the an fitting and the bleeder valve on one of my brake calipers? I am somewhat reluctant to do this because the bleeder valve has a coating of sealent on it and I don't really want to break the seal without checking first. But I have tried every position with the holes in the brake mounting flange and U-810 and although it came out fine on one side with the bleeder valve down the other side has the bleeder valve up when the caliper is installed on the wheel?
Old 02-12-2007, 10:45 AM
flyeyes's Avatar
flyeyes flyeyes is offline
Go ahead and swap them out--you'll break the "seal" when you bleed them anyway.
You might also consider swapping the O-ring out for one made of Viton (tolerates higher temps), especially if you have an A-model. There is some discussion in the archives.
The brakes are stone simple, and I don't think you could possibly hurt them by taking them apart, except maybe if you cross-threaded a fitting or put the puck in upside down. You should check anyway, since some brake assemblies were apparently shipped from the factory several years ago with the pucks upside down, which less to brake failures.
James Freeman
RV-8 flying
Old 02-12-2007, 03:01 PM
Davepar's Avatar
Davepar Davepar is offline
Just to make it clear--you have to swap the fittings in one of the brakes. No other choice. Just use some new teflon paste (not tape) when you put the fittings back in.
Dave Parsons, Seattle, WA, RV-7A, sold
www.dualrudder.com/rv7 - building blog
RunwayFinder.com - airport info, online charts, live METARs, TFRs, etc.
Old 10-05-2009, 04:44 PM
Flying Scotsman Flying Scotsman is offline
I'm about to do this, but the sealant or whatever they've put on the bleeder fitting looks like freaking gorilla glue or something. Simple (but considerable) hand force with a properly sized socket and wrench didn't budge it, and I'm hesitant to do anything lest I tear up the fitting (or worse, break it off).
Suggestions as to the best way to remove this glued-in fitting? TIA...
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 10-05-2009, 05:44 PM
gasman gasman is offline
Use a small pen tourch and heat the area around the fitting. It just needs to be heated about 100 deg hotter than what it is to help release the part. You might also try a hair dryer. But a pen tourch is a fun tool to have. And it works great for solder jobs and heat shrink................
Old 10-05-2009, 06:16 PM
AltonD's Avatar
AltonD AltonD is offline
Use a six point socket as well as the heat.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
