Old 07-19-2017, 09:03 PM
macrafic's Avatar
macrafic macrafic is offline
Default Seat Belt Hardware
Can somebody tell me which plan sheet contains the callout for the hardware that attaches the seat belts to the seat belt anchor cables in the baggage area?
(RV-7 or RV-7A?)
Rich and Cindy Macrafic
Rochester, MN
Flying
Old 07-20-2017, 06:49 AM
TX7A TX7A is offline
Drawing 29
Area G7
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 07-20-2017, 07:51 AM
macrafic's Avatar
Originally Posted by TX7A View Post
Drawing 29
Area G7
That reference is for the lap belt mounts. I need the hardware callout for the shoulder harness to the harness cable in the baggage area.
Rochester, MN
Flying
Old 07-20-2017, 08:01 AM
Drawing 26
Detail D
If you're talking about where the harness connects to end of the cable, then I don't recall that there was a drawing.
I think I have either an AN4 or AN5 bolt washer(s) & nut; whatever the hole diameters are.
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 07-20-2017, 02:37 PM
texdog texdog is offline
Smile seat belts
Rich,
Are you going to get this done by next week? I need to buy you a beer at OSH.
Fred
T82 Fredericksburg,Tx.
Don't make easy hard!
Master Pilot Award
RV6A owner N6711
L19 sold
ATP/FE/CFI 10 Type Ratings.
Old 07-21-2017, 02:26 PM
macrafic's Avatar
Appreciate the help Sam, but again that is not what I need. Your suggestion shows the hardware needed to attach the shoulder harness cable to the aircraft. What hardware is used at the other end of that cable to attach the shoulder harness itself?
Rochester, MN
Flying
Old 07-21-2017, 03:16 PM
macrafic's Avatar
Originally Posted by texdog View Post
Rich,
Fred
Fred, the plane is done (minus a few interior parts yet), paperwork is submitted and it will undergo inspection (hopefully accompanied by an airworthiness certificate) right after we return from Osh.
We are at Oshkosh now. 2 nights at the Hilton and 5 more at the dorms. What is your status?
Rochester, MN
Flying
Old 07-21-2017, 05:23 PM
az_gila's Avatar
az_gila az_gila is offline
If it's like the -6s, and each end of the cable has the same fitting, then the same AN4-7A bolt and hardware will work.
The harness simply has a "tab" that fits in the slot in the cable end fitting.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 07-21-2017, 07:23 PM
Smile Seat belt
Rich,
We can show you when we get there. Judie and I plan to be in HBC early Monday morning. Don't forget the social Monday night.
Master Pilot Award
RV6A owner N6711
L19 sold
