Tubing Sleeve
I went to the local hardware store and picked up some poly tubing, same stuff you have in your kit, only larger diameter. Split the tubing and slide full length onto the fuel line. The idea is to protect the line from vibration, chatter, and rubbing on the fuselage and the cover.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
