02-12-2007, 07:51 AM
Bellcrank bracket attachment
On one side of my -7, the bellcrank bracket binds whenever the AN4-32A bolt is torqued to spec, both the high and low values. The bracket and brass bushing are both burr free and everything moves freely until the last bit of torque has been applied. Appears to be either a slight deformation of the bracket or the brass bushing hole may be slightly off center. In lieu of reordering bracket and bushing, does any one see a problem with going to a drilled AN4-32 bolt and using a castellated nut with cotter pin. The bushing will be held firmly enough to allow the bellcrank bracket to move freely on the brass bushing as per Van's design. I intend to run this by Van's tech group also.
Thanks, David
02-12-2007, 09:12 AM
I was wondering about this too..
I haven't yet attached my bellcrank but it is coming soon, maybe some experts can help me?
It looks like the design is such that the bushing is to be trimmed so that it is slightly longer than the bellcrank, so that when the bolt is tightened the bushing is captured between the brackets. This would leave the bellcrank free to rotate on the bushing. The bushing doesn't rotate, right?
I have to ream out the inside of the bushing for the bolt (1/4 inch??). What is the best way to do this? I have a 0.250 inch reamer that I could put in the drill press but how to I hold the bushing? I saw someone wrapped it in duct tape and held it with pliers.
Also, what is the best way to trim / cleanup the bushing?
Thanks in advance,
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
02-12-2007, 09:36 AM
The bushing should stick out just slightly from the bellcrank, and you're correct, it does rotate about the bushing. The bushing does need to be reemed to 1/4" for the AN4 bolt. I put the bushing in a vice (with appropriate padding), and drilled. The bushing needs to be secure for a straight hole. I sure couldn't do it with a pair or pliers holding it.
Then I put the bushing in my drill press to smooth the OD with scotchbrite.
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
02-12-2007, 09:39 AM
if i was doing that
i would uses a castelated nut with a fiber lock insert as a secondary safety.
http://www.aircraftspruce.com/catalo...es/ms17825.php
but dont let the bolt turn in the hole when in use.
MS17825 Self-Locking Castle Nuts
Manufactured to standard castle or shear nut specifications with a nylon insert added for positive safety. Use it throughout the control system. Should the cotter pin used with castle nuts be over looked you will still have a safety...
William Weesner/ still kicking.
02-12-2007, 11:00 AM
forgot to mention
inside this weldment the tube has bumps from the welding on of the levers. this is what hangs on the brass bushing. polish this out before changing methods. or you'll likely end up with the same result.
02-12-2007, 11:02 AM
Did you just use a hand drill with a reamer or did you try to align the vice under the drill?
Thanks for your help - I think I'm obsessing about this bushing!!
dave
Marion IA
02-12-2007, 11:43 AM
Thanks guys,
I have about decided to continue with the emery cloth/dowel method I was using on the bellcrank tube. I do not want to do any more to the brass bushing. In discussing with Van's tech support. Ken (Don't know which one.) stated the tube moves during the welding process(obviously) and almost always causes some disstortion in the tube. Either a reamer or other methods such as my emery cloth/dowel will open it up enough to allow the the bracket to rotate. The bracket does not have to move 180 degrees so even binding may be present without affecting control movement. Probably need to obsess more after the aileron is attached rather than before. As long as the bracket rotates on the bushing, not the bushing on the bolt everything should be ok.
02-12-2007, 12:43 PM
dave
Yup, a hand drill with the bushing in the vise. I obsessed about it at first too. After the first one, it's no biggie. Much easier than I thought it was going to be. Once it is started square, it really has no place to go but straight in to the bushing. Just make sure to get it going square to begin with.
Get used to it...there are several more that need to be done in the fuse kit.
Chad Jensen
02-13-2007, 02:58 AM
Hi Dave,
I am FAR from being an expert ...but after clamping my bushing in the vice on my upright drill and trying to do this by eye ( and ordering a new bushing from Vans  ) I ended up getting a metal rod from the local hardware store which matched the " before " I.D.
I fitted this in the drill and used it to line everything up in the vise and then replaced it with the 1/4" drill ....... worked OK for me...
But why can't Vans just source these bushings with the correct 1/4" I.D. ???? They must be enough numbers involved OR maybe drilling these out just tips all builders over the 51 %.......
David J. D.
RV 7A QB (but possibly slowest builder in Europe  !)
Hannover,
Germany
VAF # 776
02-13-2007, 07:34 AM
This would be a far stretch for me to believe. There is far more building to these RV's than I ever even came close to on my previous built experimental aircraft.
My understanding of the rule is that it is not about the idea that we have to build 51% of everything that has to be done to build an airplane. It refers to the fact that the builder does 51% of the tasks. In other words, if you have to construct 50 ribs for the wings, if you build one of the ribs and then have the factory build the rest you have proven that you have worked on that one task of building a rib. As long as you do so with all the other tasks up to and exceeding 51% of the needed tasks then you comply with the rule.
