Old 06-09-2018, 05:25 PM
RandyAB RandyAB is offline
Originally Posted by johnbright View Post
Thanks Charlie... your comments inspired me to add a second 10-32 stud.
More photos at https://photos.app.goo.gl/ZKjbqnU3DfkUKNex2
Forgive my ignorance but why wouldn't you just stack the terminals for the primary and secondary power inputs on the stud provided? Seems like there is plenty of room.
______________________
Randy P.
1st time builder
RV10 - QB wings and fuse. Working on cabin top
St. Albert, Alberta, Canada
Reserved:C-GRPY
Old 06-09-2018, 05:40 PM
johnbright's Avatar
johnbright johnbright is offline
The concept is that if there is somehow a failure at one stud there will be a backup stud. There will be two independent power sources into the bus and it gives greater reliability to have separate studs also.
John Bright, RV-6A 25088, N1921R reserved, at FWF
O-360, 8.5:1, vert sump, dual SDSEFI EM-5-F
Schematic and other electrical related files
Instrument panel CAD jpg images
Construction Photos
Newport News, Va
Old 06-09-2018, 05:42 PM
rv7charlie rv7charlie is offline
I can follow his logic. If you feel you need redundant power feeds to a bus, the single stud would be a single point of failure for both feeds if it came loose.
Old 06-09-2018, 06:59 PM
rmartingt's Avatar
Thanks, John! I've been musing over that very idea and you've saved me some work. Nice pictures!
RV-7ER - finishing kit and systems installation
Old 06-09-2018, 10:16 PM
Ya I suppose. Unlikely but possible.
Randy P.
1st time builder
Reserved:C-GRPY
Old 06-10-2018, 09:48 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
As I posted in the CPI thread, if you're concerned about a single stud, just split your power supply setups with 2 smaller fuse blocks, say a couple six slot ones instead of a single 12 slot.
I'm not sure how the stud would fail on the Cole Hersee one I showed, since it's actually a bolt penetrating the power strap, unless you way over torque it. Are you folks worrying about all the single points of failure inside that single engine up front too?
Maybe we should be looking at fitting a couple of these to drop out of the belly if the electrical system or powerplant takes a dump?
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 06-10-2018, 10:21 AM
rocketman1988 rocketman1988 is offline
Default but...
What the failure mode on that system?
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 06-10-2018, 10:29 AM
Walt's Avatar
Walt Walt is offline
Or one of these perhaps...
https://www.ebay.com/itm/Ram-Air-Tur...-/282855057141
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 06-10-2018, 12:11 PM
rv6ejguy's Avatar
Originally Posted by Walt View Post
My idea covers failure of both powerplant and electrical systems plus propeller malfunctions too...
Old 06-10-2018, 12:14 PM
rv6ejguy's Avatar
Yes, I see, we'd need independent ignition and fuel systems for each turbine plus a separate door and actuator system to drop them into the airstream independently. Plus a fire warning system, fire extinguishing systems and N1 indicators...
