Old 02-10-2007, 06:08 PM
westwinds westwinds is offline
Default Odyssey PC680 size
I am hoping someone can give me accurate dimensions for the Odyssey PC680 battery. I have gotten widths from 2 7/8" to 3 1/8" and lengths from 7" to 7 1/4". I want to size the tray with 1/8" extra both ways. Does anyone have the battery out so they can give me these dimensions at the bottom? Thanks for the help! Tony
Old 02-10-2007, 06:14 PM
JoeBlank's Avatar
JoeBlank JoeBlank is offline
Default Dimensions
From Vans website:
The Odyssey battery has excellent cranking power (600 amps) in a small, light battery with dimensions 7 3/16" long by 6 1/2" tall by 2 7/8" deep and with a weight of 14.5 lbs. Dry Cell technology means no leaks and longer shelf life.
http://www.vansaircraft.com/cgi-bin/...duct=batteries
Cheers!
Joe Blank
RV-6
IO-320-D1A
Advanced Flight Systems
Van's Aircraft Inc. Technical Support-Retired
EAA Tech Counselor & Flight Advisor
www.westcoastravens.com
Old 02-10-2007, 07:03 PM
Kevin Horton's Avatar
My PC680 measures out to 2.95" x 7.05" at the bottom. It is very slightly larger at the top (roughly 0.04" larger on both dimensions).
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 02-10-2007, 10:22 PM
Thanks Kevin! Tony
