07-05-2017, 05:15 PM
source for oil return hose
Is the hose used to connect the oil return lines to the case typical automotive hose or something special? It looks like one of them is weeping a bit of oil that simply tightening the hose clamps isn't seeming to cure. I only need a couple inches of it, so I'd like to source it locally (quickly) if possible. Thanks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
07-05-2017, 06:12 PM
Super Moderator
I laways replace them with MIL6000D OIL AND COOLANT HOSE from Spruce. Much thicker, and doesn't weep. Lasts much longer.
Get the MIL6000-6. 2' is enough to do the engine.
Vic
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
07-05-2017, 07:12 PM
power steering return hose
Power steering return hose. This hose is on the low-pressure side and returns the oil from the steering gear back to the reservoir. Also, use spring clamps instead of worm-drive. They maintain even pressure as the hose shrinks with age and don't have a single pressure point as worm clamps do.
Below is my -6 with ~700 hours on the hose:
07-05-2017, 07:57 PM
A small amount of Fuel Lube / EZ Turn applied to the return line nipples will generally prevent leaks. Don't put so much that you risk getting a glob of it getting inside the hose.
Erich
07-06-2017, 10:09 AM
You can find SAE 100R6 -6 hose and it works well. Mil 6000 is really what you need like Vic suggests.
Ridgeland, SC
07-06-2017, 08:30 PM
What size clamps did you use? Link specs in millimeters.
Blain
R-22 sold.
RV-8 AW Cert 02-09-17
N82 Sierra Tango
Avatar courtesy of AircraftStickers.com!
Dues gladly paid thru Nov. 2020(my reminder ).
07-06-2017, 09:08 PM
You can find a good assortment of these clamps as Mcmaster Carr. Each size has a fractional range that applies to the tubing O.D.
Larry
07-06-2017, 10:40 PM
Gates' spec for the hose says that it's 0.655" OD, which is 16.6mm and 17mm is close.
And, as Larry suggested, McMaster Carr is where I got those originally. These are probably what I used (15 years ago).
Heinrich
07-07-2017, 11:48 AM
Cool. That's what size you had the link open to, but I didn't want to assume.
Blain
R-22 sold.
N82 Sierra Tango
07-07-2017, 03:57 PM
Heinrich
And if you use the MIL-6000 hose the OD range is .688" (17.48 mm) to .750" (19.05 mm)
Would be an 11/16 inch size in good old US units...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
