Old 07-04-2017, 12:19 PM
TJCF16's Avatar
TJCF16 TJCF16 is offline
Default Antisplat Cowling Door question
Does anyone have a photo of exactly where they installed the door at on the cowling? I laid it up next to the cowling, not sure where to put it. The cowling seems to be more curved and the door flat. If I move it further aft and in board it seems better. I want to put it on the left side.
Tim Crouch
RV-9A N626TC
"Merlin"
Old 07-05-2017, 01:37 PM
PerfTech's Avatar
PerfTech PerfTech is offline
...Move it as you say, inboard as far as possible, and to the rear edge of the honeycomb sandwich in the cowl. Thanks, Allan..
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 03-19-2019, 09:15 PM
VIN2020 VIN2020 is offline
Default Finally Got The Courage To Cut The Cowl
Finally got the courage to cut the cowl, because I had too with constantly limping along with high oil temps. I so glad I did, problem solved.
https://photos.app.goo.gl/KtUDupm39ens6Kzz9
Blake Graham N801RH
