Old 02-10-2007, 10:48 AM
Bryan Wood's Avatar
Bryan Wood Bryan Wood is offline
Default Alternator Question
A friend with a 1978 172 has had 2 alternators fail. He has had the plane about 2 years and it has happened again. While talking about it he mentioned that part of his checklist during run up is to turn off the alt switch to see if the annunciator lights on the panel. Then switching it on the light goes off. Something about this seems like it would blow the diodes in the alternator by always bringing it back on line with the panel all lit up and everything running. What are you thoughts? He says that the POH has this in the checklist. It's been so long since I've flown a spam can I can't remember for sure but don't remember doing anything like this on my Cherokee. Anyway, I told him that I'd ask this here on the RV group since there is such a broad knowledge base to tap into.
Bryan 9A Sold
Beech S35, and daydreams of a Super 8 or a Rocket starting to take over my brain.
Old 02-10-2007, 06:55 PM
osxuser's Avatar
osxuser osxuser is offline
Thats normal procedures at the flight school I work at, and it doesn't seem to have an adverse affect, I'd be checking out the regulator or wireing, could be something it CAUSING the failures. It also could be that he is using Kelly Aerospace rebuilds and the just suck.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 02-10-2007, 07:07 PM
Bryan Wood's Avatar
Thanks Stephan, we found the problem today. The shielded wire between the alternator and the regulator was rubbing against a clamp and wore thru. It looks like he replaced an alternator a couple of months ago for nothing.
Best,
Bryan 9A Sold
Old 02-10-2007, 07:59 PM
Geico266's Avatar
Geico266 Geico266 is offline
I just happen to have a 1977 Cessna 172 POH in my flight bag for stayovers in hotels when I can't sleep well. Anyway, I looked up the Preflight check list on Page 4-7, Paragraph #2, Item #8C = "Engine Instrucment and Ammeter --- CHECK"
Doesn't mention anything about cycling the switch, just says to look at the ameter and see if the alternator is charging. Could be the 1978 had an idiot light?
Okay, I'm going back to sleep now, this has been my contribution to the aviation world for the day.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
