Old 02-09-2007, 09:15 PM
pilot28906 pilot28906 is offline
Default VS or HS First?
I am planning on starting on the emp soon and see that the manual says start with the HS. The VS looks less complex; is there any reason that you must start with the HS?
John
Old 02-09-2007, 09:21 PM
dan's Avatar
dan dan is offline
"Must" is a strong word, but put it this way...
The HS has a BOTTOM.
If I need to expand on that lemme know...
Dan Checkoway RV-7
Old 02-09-2007, 09:30 PM
java's Avatar
java java is offline
Default My opinion...
...and you get what you paid for it.
VS is easier (one spar, smaller part, easier access). Either is fine to start. I'm only just completing my emp, so whether that is a strong or weak indicator of reliability of advice... you'll have to choose. You won't go wrong either way, just get building.
JV
Calgary, Alberta, Canada
RV7 QB - Airframe largely complete, sans canopy and glass... unfortunately sold
RV6 - O-360-A1A, Hartzell CS, dual G3X VFR... purchased
Dues paid 2015
"Being defeated is only a temporary condition; giving up is what makes it permanent."
-- Marilyn vos Savant
Old 02-09-2007, 09:47 PM
szicree szicree is offline
You definitely got a chuckle out of me with that one, Dan. Very good advice and it really reminds me that Van has got this stuff pretty well figured out.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 02-09-2007, 10:02 PM
Default Bottom?
Dan,
Please expand on the "Bottom" part.
John
Old 02-09-2007, 10:07 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
My advice is that, hands down, do the VS first. If you search through these threads you'll see MANY builders give this advice as well. The VS is simpler, smaller, and much cheaper if you mess something up the first time around. If you use a swivel flush set it is virtually impossible to dent things up. Just practice a couple rivets first.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 02-09-2007, 10:09 PM
txaviator's Avatar
txaviator txaviator is offline
Default Bottom...
No to speak for Dan...BUT....
The bottom part he refers to, means that on your first session of setting rivets, the BOTTOM of the HS (which nobody will typically ever see) is a more "forgiving" place to have a slip of the rivet gun, etc.
In other words, start with the HS. The instructions do this for a reason. If you make a "smiley" when the rivet gun may slip, it will be on an area which will not be seen. By the time you get to the VS, you'll hopefully be riveting with much more confidence
Gary Robertson
Arlington, TX
RV-12 Built / Sold / Flying
Currently Flying: Cessna Skyhawk 172
Rebuilding a true barn find J-3 Cub
Old 02-09-2007, 10:10 PM
Sparky's Avatar
Sparky Sparky is offline
Default The bottom is out of view
My guess is that Dan is referring to the bottom is out of view, therefore any screwups are not seen.
Paul Winkels
RV7 Standard Build - First flight 4/16/2016 - Now Flying!
Old 02-09-2007, 10:15 PM
G-force's Avatar
G-force G-force is offline
I believe he means all your beginner mistakes and dents can be on the bottom side of the HS where they are not visable Personaly, I built about everything at the same time. The Vans directions seem to be arranged to give you a "feel good" boost by totaly completing each piece one at a time. From a time managenment point...this suck. I did as much to every piece of the kit that I could while I was doing that process...such as fluting ALL the ribs at the same time, deburring ALL the holes at the same time, dimpling ALL the skins at the same time, etc, having all the skeletons ready to prime and assemble at the same time, etc. I suppose if your inexperienced at metal fabrication and general shop procedures, I can see Vans way of doing it...you get a taste of each stage, learn as you do it, and mistakes will be isolated to a small number of parts.
Mike Sumner
Castaic, Ca
philb philb is offline
that's where all the smilies are supposed to go.
wish it worked for me, i've got several more noticeable smilies on the tops of my elevators and HS than i have on the bottoms!
phil kslc
rv10 emp, slobuild wings shipping...
