Old 06-30-2017, 04:00 PM
JohnInReno's Avatar
JohnInReno JohnInReno is offline
Default Bore scope Exhaust Valves
I welcome comments or suggestions on these 4 exhaust valves. The engine is a Superior IO-320 with roller tappets, dual Pmags, and 400 hours since new.
Please pay special attention to #3 which is exhibiting erratic EGT at idle only. Possible sticky valve? Cylinder #2 also has a half moon mark on the edge that I can't explain.
Obviously, I am new at this.
Cylinder #1
Cylinder #2:
Cylinder #3
Cylinder #4
John Morgensen
RV-9A N946PM 600+ hours since 2013
Nevada/Arizona
Old 06-30-2017, 06:51 PM
BillL BillL is offline
The edges on #2 and #3 look suspicious. You might get a picture with the valves open and get a look at the seating band. A leak down test listening at the exhaust pipe is another diagnostic to be done. All together maybe a picture emerges.
Bill
RV-7
Lord Kelvin:
Old 06-30-2017, 07:07 PM
tim2542 tim2542 is offline
Symmetry and the look of burned pizza is good.
I agree with Bill, leakdown test is in order, and if nothing definitive is found let it develop and look again in 25~50 hrs.
Check this out:
https://www.aopa.org/training-and-sa...e/valve-safety
Be sure to download the poster.
Tim Andres
Old 06-30-2017, 07:13 PM
pa38112 pa38112 is offline
They look good to me. 400 hrs is time for a valve wobble test. That is the only way you would find a sticking valve.
What do you mean by erratic EGT at idle?
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 06-30-2017, 07:24 PM
Aggie78 Aggie78 is offline
Default Savvy Analysis
Engine monitor with download capability?
You might consider signing up for their pay service, they have an analytics program called "failing exhaust valve analysis" or FEVA that has a very good probability of predicting whether you have a problem.
Their website has more info on the subject.
https://savvyanalysis.com/content/feva/
Rob Schroer
RV-7/N75WV
YIO-360-M1B
New Braunfels, Texas (KBAZ)
VAF Monthly Donor
Old 06-30-2017, 07:32 PM
JohnInReno's Avatar
Default Flight data
I am a subscriber to SavvyAnalysis. This link should work:
https://www.savvyanalysis.com/flight...7-06e555a43bd2
John Morgensen
Nevada/Arizona
Old 06-30-2017, 07:34 PM
JohnInReno's Avatar
Default More pictures
I will try to get pictures with the valve open. A leak down test is also on the list.
john
John Morgensen
Nevada/Arizona
Old 06-30-2017, 09:43 PM
You can also watch the valve open and close, I've spotted a worn guide doing that. You can see the valve slip sideways just as it closes. Obviously, don't squish your gadget with the piston.
Tim Andres
Old 07-01-2017, 06:28 AM
scard's Avatar
scard scard is offline
That pattern at 11 o'clock on #2 would have me looking in there often.
Scott Card
CMW E-Lift
Old 07-01-2017, 07:41 AM
Isn't that just a section of lead flaking off? There is no discoloration.
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
