For those who haven't already discovered it yet. I had erroneous engine temp readings pop up after about 65 hrs. of flying our new RV14A. The number 1 cylinder was fluctuating from 100 to 495 degrees, spinning like a top. Numbers 3 and 4 started out OK but then went to reading 100 degrees lower than they did one minute before. Here was the cure: All we did was trace the sender wires back to the spade connections inside the engine compartment. We disconnected and then reconnected each wire three or four times. All readings went back to normal. I guess a little vibration/moisture/corrosion took place and was eliminated by this process. I love simple fixes.
I have had same problem with the EGT spade connectors. I ordered Electronics International Overlap connectors from aircraft spruce and am going to cut the spade connectors off and use the overlap connectors instead.
+1 for this solution. Otherwise it seems you have to keep plunging and unplugging the spade connectors, or worse you replace it thinking the unit is bad
John
9A - 92129 / N1354J First Flight 5/2/2015
Dues paid
