Old 02-09-2007, 03:14 PM
philcam's Avatar
philcam philcam is offline
Default Cheap HID landing lights?
Has anyone tried a HID conversion kit in their regular Duckworks rectangular landing lights?
One like this: http://www.pilothid.com/h3.html This kit is $189.99, but similar ones can be found on ebay for $90 - $150.
They have kits for the H3 bulb Duckworks uses.
Phil Campbell
Eagle's Nest Projects
VAF # 1043
Builder # 82699
DFW Metromess
Old 02-09-2007, 04:04 PM
Dayton Murdock's Avatar
Dayton Murdock Dayton Murdock is offline
Default PAR 36
Where do you find PAR 36 lamps with a replaceable h3 blub?
Dayton Murdock
VAF#408 RV4 N359DM Flying 1046 hrs 7/16/19
Builder Log
Old 02-09-2007, 04:11 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Read the brand name on the box-------------obviously meant for aircraft use.
Mike
Old 02-09-2007, 05:54 PM
az_gila's Avatar
az_gila az_gila is offline
Question Wig-wag?
Anyone know if these can be "wig-wagged"??
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-09-2007, 06:31 PM
philcam's Avatar
Dayton,
You don't use a PAR 36 lamp. The regular Duckworks rectangular kit uses a 55 or 100w H3 lamp.
This kit appears to be a replacement for "regular" H3 lights bulb in autos, why wouldn't it work in an aircraft since the Duckworks kit is based on an automotive type headlamp.
You might be able to wig-wag the HID lamps. Look here, they claim this unit will work on HID lights:
http://www.creativair.com/wigwag-fla...amps-p-89.html
Phil Campbell
VAF # 1043
Builder # 82699
DFW Metromess
Old 02-09-2007, 07:25 PM
mannanj's Avatar
mannanj mannanj is offline
Default HID Wig Wag
Negatory on HID Wig Wag. These lamps have a ballast and require warm up.
From all my research, you'll end up with and expensive experiment if you try. Why aren't these all as simple as we'd want them to be??????????
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 02-09-2007, 09:04 PM
az_gila's Avatar
Thumbs up Warm up period....
Apparently the CreativAir flasher gets around this by letting the ballast "warm up" for30 seconds before starting flashing....
Check their installation instructions..... bottom of the first page...
http://www.creativair.com/source/_inst/aviflash.pdf
Sounds like the DuckWorth light, this HID H-3 bulb conversion and the CreativAir flasher would be good for a bright "be seen" combination.
gill in Tucson
Gil Alexander
Old 02-09-2007, 09:28 PM
N62XS N62XS is offline
Default eBay?
How do these look?
http://cgi.ebay.com/ebaymotors/HID-C...ayphotohosting
IHN,
2020 Dues Paid
Robby Knox
THEM: Why do you always carry a knife?
ME: I can't open a bag of chips with my Glock!
Old 02-09-2007, 10:31 PM
RV_7A RV_7A is offline
Yeah I like that and along with the title at the top of that page "Brighter Roads in Dark and Foggy Conditions"
LMAO !!!
and yes there is a company that makes a WIG-WAG HID kit. They claim the ballasts are specialy designed for this use.
http://www.aerovisions.com/hid/hid_pulsing.html
According to Duckworks, ballasts designed for use with D1S bulbs have much lower noise than others like D2S and later gens.
-Jeff
www.JeffsRV-7A.com
N808TX
Old 02-09-2007, 10:41 PM
petehowell's Avatar
Default D1S Technology
When I looked into this, the aircraft HID people were all using D1S units. The same units can be found in Audi A4 and S4 cars. Wrecking yard and/or ebay should get you some ballasts and bulbs for 125-140 per side. I adapted these to a DW 100W kit and have a nice light.
From the Aerovisions website:
We use only third generation D1S bulbs for our landing and taxi lights
with integrated igniter and separate electronic ballast as pictured below. This results in greatly reduced EMI and RFI.
I'd look into the quality of the H3 HID units out there. Some have some less than stellar reputations for bulb/ballast life.
Pete
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
