You might have lead fouling of your spark plugs if you have a low compression engine. Be sure you lean properly and there are some other things you can do to reduce or eliminate the problem. It's a big problem with my C-75 Continental, which fouls plugs in 20 hours on 100LL, but I understand it is less of a problem with Lycomings.
