  #11
Old 06-26-2017, 11:14 AM
Caveman's Avatar
Caveman Caveman is offline
Scott,
Are you just wanting to take a passenger for a ride without aerobatics or for an aerobatic ride? You may already know of all this...
https://www.atsb.gov.au/media/24397/...701033_001.pdf
Here's a good thread on 4's and aerobatics with passengers:
http://www.vansairforce.com/communit...d.php?t=112843
Joe Schneider
RV-7, IO-360, BA Hartzell, N847CR
Flying since 2008
Old 06-26-2017, 12:53 PM
rvbuilder2002's Avatar
Originally Posted by ChiefPilot View Post
If the weight addition is in fact linear, then you've done the math correctly by starting with the aerobatic G loading and extrapolating from there. But the weight addition won't be linear - it will be concentrated in the fuselage...in the passenger seat, to be exact.
What effect would this have on the bending moment at the wing root? The extra mass is no longer linearly distributed along the span of the wing (or along the length of the fuselage), which would imply that the bending moment at the wing root, if linear, has some coeffcient on it which probably results in a G-loading less than achieved by linear extrapolation.
Ding, Ding, Ding...... we have a winner.
This is why if you extrapolate the max gross weight of any of the aerobatic RV's, against it's approved aerobatic gross weight at 6 G's, it doesn't work out in round #'s
Scott McDaniels
Hubbard, Oregon
Old 06-27-2017, 07:04 AM
Scott Hersha Scott Hersha is offline
Thanks for all the responses everyone. My main interest was in determining if the G load limits were a linear calculation. It sounds like they are/or not - depends on whose explanation is correct. There are other discussions here that says the aerobatic gross weight limit doesn't include wing fuel, which would also indicate that 'spreading out' the 100 pound increase over the airframe isn't necessary. Not sure I believe either one of those ideas. My only interest here was to be able to take an adult for a ride in my RV4. Not planning on ever doing aerobatics at that weight, or with someone in the back seat. I've done W&B calculations with a normal sized adult in the back and as long as I have about 10 gallons of fuel or more, I'm still within the CG limit - but over the 1500 pound max limit. If the calculation was linear, then the max G limit at 1600 pounds would be 5.156. I thought that limiting my G load to no more than utility category (+4.4/-1.75) any time I'm over the aerobatic gross weight would be safe. I have done testing at an increased gross weight and find the airplane to be controllable and stable in all normal maneuvering right down to a stall. Stick forces in pitch are, of course much lighter, but not that much different than at 1500 pounds. Power isn't a problem with an O-320 that produces approximately 175 hp, and takeoff and climb performance are still very good off our hard surface runway at 630 feet above sea level. Not sure I'm going to change anything in my POH, or W&B paperwork, because it's still unclear what is safe and acceptable.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
Old 06-27-2017, 07:15 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
That's been a thing that just won't die. The factory weighed in on it a couple years ago: https://www.vansaircraft.com/pdf/let...2015-11-20.pdf
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 06-27-2017, 09:42 AM
luddite42 luddite42 is offline
There is no such thing, in absolute terms. I'm unclear on your concern given your statement about not doing acro with a passenger when operating above aerobatic gross. Why are you trying to nail down the theoretical "exact" G-limit when over aerobatic gross when no acro is involved? Is this a true concern of yours, or do you just like theorizing the numbers? Even when aerobatics is involved, it's not as if there's some sort of magic protection at the 6G threshold, and that you enter "unsafe" territory with any amount under that number.
Old 06-27-2017, 02:25 PM
I'm just trying to stay within my written limitations in case I get ramp checked with a passenger. I know what safe is. Just trying to cover my buns, and I'm selling it, so I want to make it right.
SH
Cincinnati, OH/KHAO
JAN2020
