Old 10-01-2017, 08:55 PM
mfleming's Avatar
mfleming mfleming is offline
Talking
Originally Posted by rleffler View Post
The thud that the hardcopy makes when you drop it on the desk in front of FSDO will make getting your Repairman easier.
Mine was three 5" binders, which overwhelmed my inspector.
bob
Nice!
Mine should make a good thud when the time arrives ;- )
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Donated for 2020 and so should you
Old 10-02-2017, 07:30 AM
219PB 219PB is offline
I have a different issue that I am wondering if anyone else has seen. Periodically I "print" a pdf copy using the option on Kitlog. Then I make a backup of my database.
Since my last successful conversion back on 9/12/15, my Kitlog will no longer convert my build to a pdf file. I have been in contact with Matt and still have not gotten it fixed. We thought that there might be a corrupt entry but I tried to print several smaller date ranges and even loaded the saved database from 2015 and it will not convert to a pdf either.
I get an error that states "An unhandled exception has occurred in your application".
I sent a copy of my database to Matt and he successfully converted it. This is a stop gap solution and would like to avoid bothering Matt every six months.
I have one computer on Windows 7 and one on 10. Same problem with both. They are both pulling from the same database file on a NAS server.
Paul Bonorden
RV-6A Flying
My Builders Website
Victoria, TX
Old 10-02-2017, 05:31 PM
doug_rv7 doug_rv7 is offline
Default Kitlog PDF print problem
Paul,
I have that problem as well. My solution is to print it as Standard (as opposed to PDF). Then, in your Standard report, select Print and in your Printer selection drop down menu, select Microsoft Print to PDF.
Doug
Old 10-02-2017, 06:37 PM
That worked great. Good thinking out of the box. Thanks!!
Paul Bonorden
RV-6A Flying
My Builders Website
Victoria, TX
