Old 02-09-2007, 10:46 AM
cjensen's Avatar
cjensen cjensen is offline
Exclamation Compressor drain frozen
It's been so freakin' cold here the last few weeks! I powered up the compressor the other night for the first time in over a month, and my practice when using the compressor on a regular basis, is to drain the water every Wednesday and Sunday after a session. I went to drain it Wednesday night, and lo and behold, when the valve was opened, nada. Not even a pinch of air.
Being that it's below zero at night, and only in to the teens during the day, it's obviously frozen.
Is there any concern here? Should I go so far as to heat the bottom of the tank and drain with a propane torch to drain it? Should I not even have used it when it's this cold? Do nothing, and wait for the spring thaw?
I don't remember having this problem last year...
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 02-09-2007, 10:55 AM
captainron's Avatar
captainron captainron is offline
Chad, if you bleed off all the air, then run the compressor until it refills, the hot compressed air will probably melt the water in the bottom, then you can drain it.
On mine, I removed the drain valve, put in a 90 elbow and about a 6" pipe nipple, then a brass ball valve and then a poly line drain to the outside. Now I can just give the valve lever a twist and all the **** drains outside the garage/shop. Where I live, no problems with freezing! Sorry!
Ron Leach
RV-7 N713CM reserved VAF # 603
Cincinnati
__________________________________________
"Wish I didn't know now what I didn't know then".
.....Bob Seger
Old 02-09-2007, 12:14 PM
frankh's Avatar
frankh frankh is offline
Default Depends how cold it is
Think of it this way, if you run the compressor and it doesn't melt the ice then you have a pretty good refrigeration dryer built into your compressed air system..This is actually a GOOD thing.
I would open the drain valve and start work...if you hear big hissing after a few hours go shut the drain...Otherwise forget about it.
Frank
Old 02-09-2007, 01:06 PM
cjensen's Avatar
Originally Posted by captainron
<snip>On mine, I removed the drain valve, put in a 90 elbow and about a 6" pipe nipple, then a brass ball valve and then a poly line drain to the outside.<snip>
I did the same thing...
I'll try running it this weekend with the valve open to see if it will melt out.
Chad Jensen
Old 02-09-2007, 01:38 PM
captainron's Avatar
So you're just frozen in that line. Throw a work light under there, then go have dinner!
Ron Leach
Cincinnati
.....Bob Seger
Old 02-09-2007, 01:45 PM
cjensen's Avatar
AH! A halogen work light! Ding, ding! Light bulb! Have to get me one of those! Didn't even think of that because my work lights/trouble lights are are LED...
Chad Jensen
Old 02-09-2007, 01:50 PM
captainron's Avatar
Ah, just get the el cheapo 100w with the tin guard around it.
Ron Leach
Cincinnati
.....Bob Seger
Old 02-09-2007, 01:57 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default just a suggestion----
You might want to support that extension about mid length with a block of wood or something.
Compressors vibrate a lot, and with the way you have it, looks like the fitting in the bottom of the tank will eventually crack.
Mike
Old 02-09-2007, 02:00 PM
cjensen's Avatar
Thumbs up Thanks!
Thanks Mike. I'll have a look at that this weekend. I *think* that it is actually supported well just resting on the pavement, but I will definitely check on it!
Chad Jensen
Old 02-09-2007, 02:12 PM
captainron's Avatar
Chad, what are you looking at for an engine? Any favorites?
Ron Leach
Cincinnati
.....Bob Seger
