Originally Posted by tomcostanza
If what you say is true, isn't right-side-up the "fail safe" position for a spring failure (in flight that is)? If it fails on the ground, it seems the worst that will happen is that the battery will discharge. But if it fails in flight, depending on how you wire things, it could result in an electrical failure.
Or am I missing something?
Good point. But I think if the spring fails inflight but the contactor is otherwise functioning normally it will continue to function. No problem. My post was only to point out why some have told me they inverted the contactor orientation. Personally, I don't think it makes a difference either way. If it's rightside-up and I cut power to the contactor but nothing happens (everything remains powered-up) at least I'll know there's a problem which requires my attention. On the other hand, if upside-down, the contactor may continue to function without indication of a problem for years even with a broken spring. Then again, how often do contactors fail?
Hmm. I don't know. If there's something "solid" to indicate one way is obviously superior to the other - that's the way I'll go. Right now it just seems like it doesn't really matter.
Fred
