Old 06-19-2017, 08:41 AM
1001001's Avatar
1001001 1001001 is offline
Default Fuel Lube -- Does Van's Sell It?
I can't find it in their catalog. I see that Spruce sells it under the name "EZ Turn" but I am getting ready to place an order with Van's and would prefer to bundle it in with the shipping from them if they sell it. I have searched the Catalog and this site but found nothing.
Am I missing it or is Van's?
Old 06-19-2017, 10:36 AM
xblueh2o xblueh2o is offline
I don't think Parker makes Fuel Lube any more. I don't know how long ago they stopped but it has been a while. EZ Turn is for all intents and purposes the same thing. I think it is even made to the same mil spec but I am not 100% sure.
I have looked at EZ Turn and Fuel Lube side by side and the only thing I could see was Fuel Lube being a little darker. Might also have been that the can of Fuel Lube was the better part of 30 years old and my can of EZ Turn was brand new.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Last edited by xblueh2o : 06-19-2017 at 10:38 AM. Reason: Mongo no type good. Mongo fix. Gooder now.
Old 06-19-2017, 04:25 PM
Jesse's Avatar
Jesse Jesse is offline
I use Seal Lube. Spruce should still sell it.
Jesse Saint
Old 06-19-2017, 06:41 PM
DHeal DHeal is offline
I have had very good success (i.e., easy-to-use, cheap, available, no leaks, etc.) with Loctite's 567 sealant for all of my RV-12's fuel, oil, and hydraulic fittings. 567 is also compatible with fuels containing ethanol -- if that is a factor in your case. I have heard that some of the traditional aviation sealants don't tolerate ethanol very well.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 940+ hours (as of September 2020)!
VAF donation through June 2021.
Old 06-19-2017, 07:39 PM
DaveWelch DaveWelch is offline
+1 for the Loctite 567. I used "Fuel Lube" actually EZ-turn as per the instructions on Kit #121 a few years back. Since then, Van's changed the instructions (and section 5 also?). They said something to the effect that Fuel Lube is a lubricant not sealant, therefore do not use for sealing fluid fittings. Since I still had relatively easy access at that time I opened, cleaned and resealed all my fittings with Loctite 567. No leaks. Just my experience. Others I'm sure will have different experiences to share.
Dave
RV12 N951DZ
First Flight 9/23/16!
No paint yet. Working on a scheme with John Deere colors or accents.
Old 06-20-2017, 10:51 AM
krw5927 krw5927 is offline
OP didn't mention trying to seal threaded fittings. Fuel Lube (EZ Turn) is quite useful for lubricating O-rings on the fuel caps and gascolator.
Kurt W.
RV9A
FLYING!!!
Old 06-20-2017, 11:04 AM
wilddog wilddog is offline
Seal Lube works for me.
Old 06-20-2017, 10:16 PM
Default True
True, but just in case...
Wouldn't be the first time one of us was working from an outdated set of plans.
And yes, fuel lube and similar stuff can be handy to hold gaskets in place when assembling things...
And, if you run out of hair gel (and still have any hair)...
Dave
RV12 N951DZ
Old 06-21-2017, 09:17 AM
The only thing I use my old Fuel Lube for is to temporarily stick washers and nuts to my fingers to thread them onto awkwardly situated bolts.
Old 06-21-2017, 11:19 AM
rwarre rwarre is offline
Default will share
I bought a tube of fuel lube when I did my first cond inspection. Still have quite a lot. I use it to lube my gas caps gaskets. I could put some in a plastic container and send it if you want. I will never use the whole tube.
