You should be able to switch between ECU's with a toggle on the panel somewhere, right? Each ECU has its own MAP sensor, so that should isolate the sensor issue.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
