Old 02-08-2007, 05:23 PM
RV4er's Avatar
RV4er RV4er is offline
Default Please ID this starter
When I bought my RV-4 this starter was installed. Can anyone give me any info on it? I assume it is some sort of auto conversion. Throw it out? Keep it?
Old 02-08-2007, 05:34 PM
Gary Bricker Gary Bricker is offline
Default Gary Bricker
Check with Sky-Tec. They are in Granbury.
Old 02-08-2007, 05:44 PM
philcam's Avatar
philcam philcam is offline
That starter looks like a starter for a Toyota 22R motor with some type of home fabricated bracket. The 22R was a 4 cylinder motor used in the 80's and 90s. I know the motor was in the Corona (before the Corolla) pick up and 4 runner, probably others. I disassembled those starters countless times after weekends of playing in the mud in my 4x4 Toyota trucks. Water would get in them and the contacts would stick. I grew up and learned to fly, much cleaner. Much more fun. Much harder on the wallet!
I second the idea about Sky-Tec. Trash that thing and go talk to Les Staples, the owner. I put one of his lightweight starters on my Grumman. Great guy and he'll have what you need.
Phil Campbell
Eagle's Nest Projects
VAF # 1043
Builder # 82699
DFW Metromess
Old 02-08-2007, 05:57 PM
Geico266's Avatar
Geico266 Geico266 is offline
Make sure to do a new W&B! lol That old start looks like it weights a ton!
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 02-09-2007, 08:22 PM
RV4er's Avatar
Default Thanks
Thanks for your replys fellows .
Old 02-09-2007, 09:09 PM
az_gila's Avatar
az_gila az_gila is offline
Question Southern California
Did your RV-4 come from S. California?
I remember someone bringing a similar arrangement to a Van Nuys EAA meeting around 10 years ago to see if any home builders would be interested...
At that time the lightweight commercial ones were relatively more expensive than they are now....
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-10-2007, 08:19 AM
RV4er's Avatar
Default Not that I am aware of
Gil,
My RV was certificated in 00 by a fellow in Ohio. However, who knows were it was started.
Old 02-10-2007, 09:49 AM
gmkonrad gmkonrad is offline
Default Probably Nippondenso
I believe your starter was made by Nippondenso. Slight variations are used on many foreign cars (Toyota and Subaru come to mind). If you look at a Summit Racing or Jeg's catalog, you will find the same basic starter adapted for automotive high performance applications. I adapted one from a Subaru to VW engine in my Dragonfly last year and I love it. It it has been working well for you, why change it.
Gary
Old 02-10-2007, 06:54 PM
osxuser's Avatar
osxuser osxuser is offline
I'd check the weight, if it weights more than around 18LB i'd dump it for a skytec.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 02-11-2007, 11:25 AM
breister breister is offline
The SkyTec starters use a Nippondenso motor. I know because I just had an automotive place repair mine.
It looks a lot like my starter...
