Need Some Tribal knowledge regarding the best way to access the bottom nut that faces the oil filter on a B&C (SD20) vacuum pad backup alternator.
Searched the posts and have not seen anything about this.
I have a LYC O320-D2A with a ECI oil filter angle adapter and extension. The Backup Alternator has shorted and needs to be replaced. The last bolt is in a restricted space.
Between the oil filter adapter body and the alternator flange I can get my hand in there and with my finger touch the studs and nut. With that said I am hoping that I could fabricate a custom made wrench so that I don't have to remove any other components to get that last nut out.
I also considered removing the oil filter angle adapter but there is also one bolt that is very restricted by the B&C Alternator body. Catch 22?
Has anyone done this and if so what route did you take? I?m not initially in favor of removing parts unless that is the only way to do it.
Best outcome is if someone on the forum has done this and has a custom wrench they could dimension and take a picture for me. I also will have to figure out how to torque that bolt with the replacement moving forward also.
Regardless, if anyone has done this I would appreciate what the final outcome was. At this point I have removed the oil filter and am considering options.
Thanks.
