Old 06-14-2017, 10:52 AM
Raymo's Avatar
Raymo Raymo is offline
Default Neoprene Rubber Replacement (SJ cowl)
The neoprene is not holding up as well as I'd hoped on my SJ cowl. I've had to replace the intake tube after about 70 hours of flying and the tubes into the plenum are showing signs of degradation too.
Wondering what others have used that holds but better over time and is flexible enough for the purpose.
Thanks in advance.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 06-14-2017, 03:09 PM
airguy's Avatar
airguy airguy is offline
My plenum transitions are doing fine but my engine air intake is showing definite signs of distress with 150 hours on it. I believe it's just wetsuit material but where to get it would be the question.
Old 06-14-2017, 03:21 PM
William William is offline
On my Sam James ram air intake I used marine exhaust water hose for the ram air to cowling connection such as this. https://www.fisheriessupply.com/trid...cean-flex-hose. You should be able to find it cheaper and it works great. I secure the hose using a hose clamp to the intake ring glued to the cowling. This hose overlaps the fiberglass ram air intake by about 1" and no clamp is needed on the ram air intake. This makes removing the cowling a snap.
Bill
RV6A flying as of November 8, 2016. N717WK
Finishing a RV10
Old 06-14-2017, 03:22 PM
bret's Avatar
bret bret is offline
I used silicone hose for the ram air intake.
Old 06-14-2017, 04:02 PM
Raymo's Avatar
Thanks. Getting the same material is not a problem. I want something that will hold up better but still be flexible.
Ray
Old 06-14-2017, 04:03 PM
Raymo's Avatar
Bill
Thanks! I will check this out.
Ray
Old 06-14-2017, 04:04 PM
Raymo's Avatar
Can you be more specific, Bret?
Ray
Old 06-14-2017, 05:43 PM
DanH's Avatar
DanH DanH is offline
Make what you want. Hose material is too stiff.
These are at 675 hours now, still doing fine...a single ply of 9oz plain weave glass soaked in two-part urethane rubber, and wrapped over a form. Andy made some too.
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-14-2017, 07:48 PM
sblack sblack is offline
Dan that's awesome. Can you give any details of the rubber?
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 06-14-2017, 11:39 PM
crabandy crabandy is offline
Scott,
I believe the rubber DanH used isn't made anymore, I've used a similar formulation from the same company "Smooth On" Urethane rubber "PMC 780 Dry" with excellent results.
https://www.smooth-on.com/products/pmc-780-dry/
RV 7 400 hours and counting
19 donation done
