I wet riveted my fuselage structure and used sikaflex pro as it has a really long working/skin time. This is critical for wet riveting as you always find you need more time than you planned on, because you had to drill a rivet out etc. When I wet rivet these types of structures I like to do so before the sealant has set, as the rivets will squeeze out far more sealant than the clecoes will, thus saving weight.
The 3m product you speak of is a fast cure adhesive, so I would be a little concerned about working time. Regarding the tensile strength, this is not really an issue, because the rivets are holding things together, what you are looking for is gap filling to stop capillary action. What you really care about when Fay sealing is surface adhesion, flexibility, gap filling ability, chemical resistance, paint ability (avoid silicones), ease of use and of course working time. Keep your tube of Sika pro in the freezer and it will last the entire project.
Good luck.
Tom.
