  #21
Old 06-13-2017, 10:54 AM
goatflieg's Avatar
goatflieg goatflieg is offline
Originally Posted by bret View Post
I wonder about this....on a off shore race boat they have what they call a stepped hull, it allows air to enter under the bottom to introduce air bubbles between the boat and water surface, to release the suction of the water and go faster. Would micro vortex generators in the paint imperfections do the same?
I always think of the Mythbusters episode where they explored whether dimples such as the ones on golf balls reduced drag; would a dimpled car get better mileage? Turns out, to their surprise, it was confirmed. I'm going to lean heavily on that reasoning if I end up with significant orange peel...
Martin J Filiatrault
Clarkston, MI
RV-8 #83507 - currently working on finishing & firewall forward.
N657AR reserved
Builder websites:
http://goatflieg.blogspot.com/
http://www.mykitlog.com/goatflieg/
YouTube Channel:
https://www.youtube.com/user/goatflieg
Dues paid for 2020... extra payment included for psychological therapeutic services rendered.
_______________________
Have you ever gotten the feeling you were smarter than you could ever prove?
Old 06-13-2017, 11:03 AM
N941WR's Avatar
N941WR N941WR is offline
[quote=bret;1180124...Would micro vortex generators in the paint imperfections do the same?[/QUOTE]
Probably not because of the "boundary layer".
https://en.m.wikipedia.org/wiki/Boun...ayer_thickness
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 06-13-2017, 01:05 PM
bret's Avatar
bret bret is offline
Every Top Fuel Dragster I've seen going 300+ MPH was painted.......so......Ok, never mind, might be the 11,000 HP or something
Old 06-13-2017, 07:01 PM
snopercod's Avatar
Default golf balls?
Originally Posted by RV Jerry View Post
...a paint job with heavy orange peel...
That works for golf balls, right?
(2020 dues paid)
Old 07-10-2017, 10:31 AM
gasman gasman is offline
Originally Posted by mturnerb View Post
When painting the airplane, simply make some adjustments to the airspeed indicator: Change "MPH" to "Kts" and you're 15% faster!
Are you sure.........
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 07-10-2017, 11:32 AM
BillL BillL is offline
Default It worked for dozer blades- only in reverse
A certain earth moving research department showed that the addition of bumps spaced over a dozer blade actually gave better performance than the smooth blade. The best blade shapes work by shearing off a layer and rolling the collected material. Apparently, the bumps reduced the viscous drag of material. Totally impractical to manufacture, but a an odd success.
Disclosure: air, fluids (water), and regolith do not have the same flow properties.
Bill
RV-7
Lord Kelvin:
Old 07-10-2017, 05:17 PM
shamer's Avatar
shamer shamer is offline
Default Much faster with paint
My RV-6 is 200+ mph faster with paint. Keep in mind that that is with a really good wax job and that it never flew without paint so the actual speed gain might be a scosh less.
Steve Hamer
RV-6
Eagle, ID
Old 07-10-2017, 06:32 PM
PilotjohnS PilotjohnS is offline
Default Yes
Yes paint makes the plane goes faster.
Without paint, eventually the wings will fall off and the plane will be slower.
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2020, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Finishing Kit 35% canopy done for now
Electrical 5% in work
Firewall Forward 5% in work
www.pilotjohnsrv9.blogspot.com
