  #11
Old 06-12-2017, 07:40 AM
FORANE's Avatar
FORANE FORANE is offline
Can't say for an RV as I only flew our RV9A with paint but can say definitely that our Lancair gained between 5 - 10 kts after the repaint.
Lancair 235/340
RV-9A (2013 - 2016)
Old 06-12-2017, 07:46 AM
Caveman's Avatar
Caveman Caveman is offline
Default Wax it.
After you polish it, put on a coat of wax.
After selecting the link below, scroll to the article "wax effects on drag"
https://cafe.foundation/v2/research_reports.php
Joe Schneider
RV-7, IO-360, BA Hartzell, N847CR
Flying since 2008
Old 06-12-2017, 07:59 AM
FORANE's Avatar
Look up REJEX on this site and amazon for reviews.
Lancair 235/340
RV-9A (2013 - 2016)
Old 06-12-2017, 11:35 AM
Rupester Rupester is offline
Not sure about speed impact, but Rejex is the greatest stuff ever for making easy bug removal. I use it on leading edges and all the "buggy" surfaces on the RV, and all my cars. GREAT stuff!
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 06-12-2017, 11:41 AM
Originally Posted by FORANE View Post
Can't say for an RV as I only flew our RV9A with paint but can say definitely that our Lancair gained between 5 - 10 kts AFTER THE REPAINT.
My interpretation of this data: the original paint slowed you down.
Old 06-12-2017, 03:47 PM
dtw_rv6 dtw_rv6 is offline
Default Paint makes you slower
I have to pull back on the throttle and take fewer flights in order to afford getting mine painted.
Old 06-12-2017, 03:57 PM
flyboy1963's Avatar
Default more data points needed!
So I would expect almost no measurable difference on a flush-riveted polished vs painted surface....surely there are 1932 NACA tests for this?????
my new ride has lots of domed rivets, and I wonder if putting a vinyl wrap over those surfaces wouldn't 'smooth' out the airflow over those heads. yes, they'd all be .002" higher, so not 'hiding' the bump, but perhaps bridging the transitions. ( Yes, it's painted, so can't quantify that effect).
....ok you guys with little wind tunnels in your hangars.....let us know how this all plays out??!?
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 06-13-2017, 09:08 AM
RV Jerry RV Jerry is offline
Many years ago I had built a canard style airplane with a very slick paint job my hanger partner had a paint job with heavy orange peel and he had a fast airplane so to make it faster he decided to give it a slick paint job. Well his stall speed went up and top speed went down, he was not happy.
Jerry Scott
Rocket II
Old 06-13-2017, 09:16 AM
bret's Avatar
bret bret is offline
I wonder about this....on a off shore race boat they have what they call a stepped hull, it allows air to enter under the bottom to introduce air bubbles between the boat and water surface, to release the suction of the water and go faster. Would micro vortex generators in the paint imperfections do the same?
Old 06-13-2017, 10:48 AM
N941WR's Avatar
N941WR N941WR is offline
My thinking is that most of the weight of the paint is aft of the CG and as everyone knows, tail heavy planes tend to fly faster.
Just a guess on my part and I could be way off base.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
