Old 02-07-2007, 09:40 PM
Larry Brons Larry Brons is offline
Unhappy Oops: Used firewall sealant instead of proseal
Uh oh! (I hate having to start a new post with that) I inadvertantly sealed the fuel float cover on the fuel tanks with firewall sealant and not proseal. I leaked checked it and it doesn't leak. So the question is how does the firewall sealant hold up to av-gas? Is it safe to leave on or should I remove the covers (arrrgghh)?
Larry Brons
RV 9A
N1695
Flying, tip-up, Aero Sport O-320-D2A
Sensenich FP, Advanced AF-3500, SL30,
KLN94 GPS, 396, Garmin GTX 327, Tru Track II
auto-pilot.
Did I mention FUN?
Old 02-07-2007, 10:21 PM
Walt's Avatar
Walt Walt is offline
Default What is the part number
of the sealant you used?
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 02-07-2007, 10:38 PM
MC CS 1900 firewall sealant
That's in Van's catalog.
Larry Brons
RV 9A
N1695
auto-pilot.
Did I mention FUN?
Old 02-08-2007, 06:15 AM
Geico266's Avatar
Geico266 Geico266 is offline
I'd call Vans right away.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 02-08-2007, 06:32 AM
bsacks05's Avatar
bsacks05 bsacks05 is offline
I would remove the covers, clean off the old sealant, and re-do with the proper stuff. Do it now while everything is accessible and you won't be worrying about it later. Rework sucks but saves time and aggravation in the long run.
Bruce Sacks
RV-9 N659DB - Flying since 7/1/06
Hatz CB-1 - Fabric covering with Polyfiber.
Warner Robins, GA
A&P
APRS KJ4EFS
Old 02-08-2007, 09:58 AM
Red face
Good advice, got the same from Van's. Oh well, it pays to pay attention. I keep telling myself this falls under the "learn from your mistakes category".
Larry Brons
RV 9A
N1695
auto-pilot.
Did I mention FUN?
Old 02-09-2007, 03:14 PM
briand's Avatar
briand briand is offline
Can you use fuel tank sealant to seal the firewall? I have half a qt left and I planned on using it for my FW.
Old 02-09-2007, 04:16 PM
Captain Avgas Captain Avgas is offline
Default Smoke or roast
Sure you can...lots of builders do...and for the same reason....but if you have a FWF fire it will be a toss up between you choking to death from the proseal smoke or roasting as the flames burn straight through the stuff.
The correct sealant is CS1900 sold by Vans (can handle flash temps to 2000 degrees F). Go to
http://www.vansaircraft.com/cgi-bin/...product=cs1900
Old 02-09-2007, 06:44 PM
Cool
Well, the official answer to the original question is... "the CS 1900 is not approved for that application". Simply put, re-do time. So, if you decide to seal your fuel tank covers with firewall sealant, don't.
Thanks for all of the replies.
Larry Brons
RV 9A
N1695
auto-pilot.
Did I mention FUN?
