Old 06-05-2017, 06:17 PM
Rupester Rupester is offline
Default O-Ring for fuel drain valve?
Where might I find those tiny O-rings that seal the fuel drains? Mine are blue Viton, but I suspect any fuel-proof material will do (such as Buna-N)
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 06-05-2017, 07:05 PM
TX7A TX7A is offline
Default Van's has them...
http://www.vansaircraft.com/cgi-bin/...product=cav110
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 06-05-2017, 07:16 PM
bhester's Avatar
bhester bhester is offline
Thumbs up ACS
Aircraft Spruce has them also, at least the black ones.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 06-07-2017, 09:16 AM
EPG Aero EPG Aero is offline
I just placed new O-rings on my drains, but still have a small seep on the left wing. They've never really sealed very well. I think it's an issue with the compression spring, or perhaps a nick in the valve. I think I'll just have to replace the drains. I ordered the O-rings from Van's.
Old 06-07-2017, 09:47 AM
JonJay's Avatar
JonJay JonJay is offline
While it is just as easy to replace with new, the drains are super simple to clean. Since they are the low point in the tank, you may find a bit of contamination that isn't allowing a full seal. It only takes a very small bit of material between the o ring and the seat of the valve to allow a drip. Pull them and clean them and I bet your drip is gone. Allow a bit of fuel to run out of the drain to insure any contamination is flushed out.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
