06-05-2017, 02:56 PM
EarthX batter warning flashing
During my last flight, proximately one hour into the flight, my EarthX warning light started flashing for about 1-2 minutes and then stopped flashing. While this event was happening all my volts/Amps were normal, putting out 14.2 volts and the draw was the normal 19-20 Amp. The EarthX cheat sheet indicates that it is not of a concern and it means the cells were imbalanced and were being charged. Just wondering if others have seen this and if so, how often do you see it happening? Any warning light going off makes me nervous.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
06-05-2017, 03:03 PM
Super Moderator
I haven't seen that, but if you are uncomfortable, give them a call.
Vic
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
06-05-2017, 03:22 PM
I saw it after installation and would turn the alternator off just to make me feel better even though the instructions indicated that all was okay. I no longer get the warning light after about 20 hours on the battery. Presumably the cells are balanced now. Everything else has always operated in the green.
06-05-2017, 03:24 PM
Vic
I called them this morning and some one is suppose to call me back. I will report once I have more detailed info from them.
Mehrdad
Dues paid
06-08-2017, 09:31 AM
Just to report back that I talked to their engineer and he assured me that short duration blinking with the volts in the normal range is OK and indication of balancing the cells. He did mention that they have change the programing of the management system this year so not to be as sensitive.
I will keep an eye on it.
Mehrdad
Dues paid
06-08-2017, 12:24 PM
I have also seen the blinking light on occasion. When I talked to Earth X they told be it indicated that the battery was under-charged. They also said that the blinking light should not worry me from a safety standpoint. In my situation there did not really seem to be any rhyme or reason as to when it would happen. Mine has not blinked for a number of months now, but I really never did anything to "fix" it. I love the battery by the way! Turns the starter more aggressively than the Odyssey that it replaced.
Bill York
Stellar Airpark (Chandler AZ)
RV-6 N477DH
Eagle II N92CE (sold)
Hiperbipe N777HT (sold)
PA22-160 N9322D (sold)
