Old 06-05-2017, 02:42 PM
219PB 219PB is offline
Default MAP sensor location
I have a question. My EFII kit states to mount the MAP sensors (2) behind the firewall. My Dynon MAP sensor is the same sensor and they state that it can be mounted firewall forward. How many have mounted their forward of the firewall? This would ease the firewall penetrations significantly.
Paul Bonorden
RV-6A Flying
My Builders Website
Victoria, TX
Old 06-05-2017, 04:39 PM
rcpaisley's Avatar
rcpaisley rcpaisley is offline
Default MAP sensor
Hi Paul,
It can go on either side of the firewall,
Robert
EFII www.flyefii.com
Protek Performance
Old 06-05-2017, 04:40 PM
Paul, I think most do mount theirs FWF.
Tom
Ridgeland, SC
Old 06-05-2017, 05:49 PM
N941WR's Avatar
N941WR N941WR is offline
I mounted mine aft of the firewall, on a piece of AA that is riveted to the upper horizontal AA that that runs across the back of the firewall.
Make sure to mount it with plate nuts to aid future maintenance.
To get the MAP line through the firewall, I used an AN807 Adaptor Hose to Universal fitting (In aluminum, Aircraft Spruce shows the picture in brass but they also have aluminum.)
I tried to put as many plastic parts aft of the firewall as I could.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 06-06-2017, 05:58 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Try to mount with the vacuum port inverted. This reduces the chances of condensation sitting on the sensor element which can cause failure over time.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 06-06-2017, 06:08 AM
snopercod's Avatar
Ideally, you want your MAP sensor located higher than the cylinder with the line sloping back toward the cylinder. This is so the inevitable condensation will drain back rather than into your sensor. If you can't do that, put a drip leg at the low point the line to trap the condensation.
(2020 dues paid)
Old 06-06-2017, 07:14 AM
Thanks for all of your input. I will put it on the firewall side up high with all of the lines sloping down to the throttle body with no drip legs. I am trying to minimize my firewall penetrations.
Paul Bonorden
RV-6A Flying
My Builders Website
Victoria, TX
Old 06-06-2017, 07:39 AM
bret's Avatar
bret bret is offline
Went with two AN 4 bulkhead fittings up high on the firewall, went through to sub panel and mounted my three MAPS there, all the avionics and EFII ECMs are on the sub facing rearward to avoid future under panel diving adventures. All accessible from the two big holes where the displays go.
