Old 02-06-2007, 09:45 PM
Jim P's Avatar
Jim P Jim P is offline
Question D-Sub Extract Tool
Dumb question maybe, but how do you use a d-sub insert/ extract tool to extract a pin from the shell?
Jim
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 02-06-2007, 09:52 PM
RV6_flyer's Avatar
It depends on what contacts are in the connnector. One style connector is high density and has more smaller contacts in the same size connector. (Green / White insert / remove tool.)
The BACKSHELL must be removed from the connector. You will be using a Red / White or a Green / White removal tool. (SteinAir sells them.)
Assuming that you are using a Mil Spec connector that has a silicone seal where the wires go in, use a drop of IPA on the tool, thread the wire through the large opening in the metal of the connector and gently slide it into the connector. You will FEEL a click when you have relased the keepers. Now pull on the wire and it should come right out.
I have done this so many times, I can do it with my eyes closed. I hope my description helps.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 02-06-2007, 10:08 PM
Jim P's Avatar
Default Thanks
Thanks Gary. Man, that was a quick response. BTW, they are standard d-subs and not the high-density.
Jim
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 02-07-2007, 07:41 AM
MCA's Avatar
MCA MCA is offline
Default Diagrams..
Jim,
Go down about half way on the page http://www.verticalpower.com/documents.html
and download the "Connector Service Manual". Should be some info in there to help you too.
Marc
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
Old 02-07-2007, 08:42 AM
az_gila's Avatar
az_gila az_gila is offline
Question Beer????
Gary.... I always thought IPA was "India Pale Ale" but that doesn't seem appropriate for use in electronic connectors....
Silicone fluid??
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-07-2007, 08:56 AM
RV6_flyer's Avatar
Silicone fluid??
gil in Tucson
IsoPropyl Alcohol
http://en.wikipedia.org/wiki/Isopropyl_alcohol
Sorry. I ASSuMEd that everyone in the Aerospace industry knew what IPA was.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
