Old 06-01-2017, 04:54 PM
LUKLA's Avatar
LUKLA LUKLA is offline
Thanks folks.
This is lots of info and it helps me a lot to make decision.
I appreciate all the inputs.
lukla
Old 06-02-2017, 01:07 PM
LUKLA's Avatar
Originally Posted by rongawer View Post
Interior primer: Rust-Oleum Self-Etching Primer: Dark Green, Aerosol Can, 30 min, 10 to 15 sq ft, ~$4 per can.
Interior paint: Rust-Oleum Ultra Touch 2x Flat Grey, Aerosol Can, 30 min, 10 to 15 sq ft ~$5 per can.
5 cans of paint used. Low cost. Easy with the "360?" spray nozzle. Good coverage. Good finish.
I will do this again.
I could not find any ultra touch . they have painters touch only. Are this both same or different. Painters touch and ultra touch.
Lukla
Old 06-02-2017, 02:38 PM
Tom023 Tom023 is online now
I used Rustoleum Professional in Machine Gray. They also have a lighter gray. Not absolutely perfect but came out pretty good. I already have had to touch up a few areas which is really easy...just grab another can, shake and spray. For primer I did use a Sherwin William Aerospace product which is two part using a spray gun.
RV14A #140083
Flying! 8/12/19
2019 Donation
Old 06-02-2017, 04:59 PM
LUKLA's Avatar
Semi Gloss/ Gloss/ Flat ?? which one is better for interior.
Old 06-02-2017, 05:07 PM
bkervaski's Avatar
bkervaski bkervaski is offline
Well, the glossier it is the easier it will be to keep clean ..
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 06-02-2017, 06:33 PM
LUKLA's Avatar
Did u used gloss or flat.
Lukla
Old 06-03-2017, 06:32 PM
scottmillhouse's Avatar
scottmillhouse scottmillhouse is offline
I also used the Rust-Oleum Self-Etching Primer: Dark Green, but used their smoke gray gloss protective enamel. Used on my 9, 7 and now 12. cheap, easy to spray and repair. No problem after 7 years on the 9. Easy nick repair by spraying some in can, let start to thicken and then apply with artist brush. Have never had good luck with the Mar-Hyde 5111 Self Etching Primer. It does not seem to stick well and will crack and flake off. If not now, when you remove a screw or otherwise cause some slight stress or movement.
Scott- 2020 donation
New RV-7A N579RV, only 80 hours now without 2020 fly-in destinations
Built RV-12, 328 hours-sold, purchased RV-12 sold, Built RV-9A, 536 hours-sold, Not completed RV-7 sold, Built Kitfox sold
Old 06-04-2017, 02:21 AM
madmaveric's Avatar
madmaveric madmaveric is offline
I've yet to try mine out (still building) but I've heard gloss may cause issues with reflections if taking photos so I used a satin finish just in case, although I then used a gloss clear coat on the panel without thinking about it.
People with a flying aircraft will give a better answer but when I asked previously the advice was to go satin/flat. I chose satin as should be easier to clean than flat.
Old 06-04-2017, 07:56 AM
rongawer rongawer is offline
Lukla
I used flat with the purpose to minimize glare in the cockpit. I personally haven't found any difference in cleaning flat vs gloss enamel paint.
The full name of the Rustoleum paint I used is "PAINTER'S TOUCH® ULTRA COVER 2X". It works very well. And for an aerosol can, they have a great nozzle setup that allows you to paint at pretty much any angle.
Ron Gawer
- RV10, Build in progress.
- RV12, N975G, "The Commuter"...many great hours and happy landings so far.
- Several others that are now just great memories for me.
Old 06-05-2017, 05:09 PM
LUKLA's Avatar
thanks a lot.
