Old 02-06-2007, 11:56 AM
REHughes's Avatar
REHughes REHughes is offline
Default How About Calling It "Upwind Entry" Instead of "Overhead" Or "Break"
The pros and cons of the Overhead Entry pattern have been discussed productively in several threads recently. The military selects this pattern primarily in response to the requirement that:
"Interval with the aircraft landing in front of you must be established by timing your turn from Upwind to Downwind."
This requirement is generated from the Prime Directive:
"Every landing aircraft must start its approach turn (from Downwind to Landing) at exactly the same spot in relation to the touchdown zone, every time."
This is why the 45-To-Downwind is is the absolute worst way to enter a pattern. By the time the entering pilot identifies the downwind and crosswind-turning traffic in front of him, his choice is to raggedly fit in, sometimes on a hazardous parallel course, or do an even more hazardous 360-Turn at co-altitude with other aircraft coming down the 45 degree entry line. The inevitable result is a long line of aircraft on extended downwinds performing what are essentially dangerous Straight-In approaches.
The Crosswind entry has many advantages in this regard, and apparently, according to some COPA articles, in Canada it has become the de-facto standard entry at many non-towered fields. The pilot has a much better view of the overall traffic situation, including aircraft taking off and starting their crosswind turn. If the pilot sees conflicting traffic, it is easy to turn Upwind and wait for the correct interval to open up, and then do the Crosswind turn to the Downwind. Note that this turn-to-Upwind then results in exactly the same the pattern as seen by an aircraft doing an Overhead at this point in the pattern.
An entry to the overhead at our field goes something like this:
Fly to a point 3 miles or so Downwind from the intended landing runway (If you call this point the "Initial", most civilian pilots will not know what you mean, but a call such as " XXTraffic, RV 24Foxtrot, three miles South, will enter Upwind for 36, XX" will generally be clearly understood. If a gaggle of airplanes is approaching the field, the various individuals and formation groups can start to "pre-space" themselves in a line coming in from the 3-mile point.
As you approach the field, align yourself slightly to the Non-Pattern side of the Runway, offset just enough to be able to see the aircraft holding short, taking off, and climbing out. The optimal altitude to use as you enter the Upwind is the subject of fairly heated opinions, but it should be close to Pattern Altitude, perhaps up to 200' above it.
As you proceed upwind alongside the landing runway, be sure to scan off to the non-pattern side to check for any traffic setting up for a Crosswind Entry, and check for aircraft climbing out, turning crosswind, already established on Downwind, or coming down the 45.
If you cannot establish a suitable interval on the other traffic (or if for some reason you find it desirable to switch to another runway) just keep motoring Upwind and leave the pattern to fly away and start the whole entry over again.
Most of us who have had a fair amount of time using the Overhead or Break recognize the many advantages of the approach, especially at busy non-towered fields. It is certainly the best way to bring a formation into the field (Do you really want to chance circling on the 45 entry line with a 4-plane?).
Using the terminology of "Upwind Entry" and explaining it to your local pilot buddies as "just another point to enter the pattern" makes the Overhead procedure much more intuitive for most pilots trained in Civilian flight schools and removes the arcane definitions.
Regards,
Hawkeye Hughes
RV-3, Skyote
Old 02-06-2007, 02:16 PM
mrreddick mrreddick is offline
Super Moderator
Location: Hangar/home at Hicks Airfield (T67), Fort Worth, TX
Default Upwind Entry?
I took my primary training in SoCal and the pattern was clearly explained to me (I already knew it from 15 years of glider flying).
Anyway, you don't (at least I hope you don't) fly an "upwind" leg of the pattern over the runway centerline, which is what you do when you enter the initial overhead pattern entry. The upwind leg is supposed to be at a safe distance, just like the downwind leg, so you can scope out the airport and any activity (possibly a NORAD or two) in the other pattern legs as you arrive.
I hate to get yet another thread started on this matter as there is already a quite lengthy one going.
Cheers!
Mike Reddick
VAF#153
Pilots N Paws Pilot
RV6A N167CW 1,900 HRS
Ft Worth, TX (T67)
Old 02-09-2007, 01:47 PM
Low Pass's Avatar
Low Pass Low Pass is offline
When I'm leading a flight around other individual GA planes, I do use this as well as other "GA" familiar terminology.
In addition to calling "x flight, flight of 4, 3 mile initial straight in for upwind pattern entry, break to land".
Next call would be near the end of the runway, "x flight, flight of 4 will break into a mid-field left crosswind to land".
The next calls are very GA pattern typical base, final, etc.
All done with calm, courtesy and adequate spacing. Anything unsafe or abnormal and I continue upwind or turn out away from the flows.
Good productive topic.
Bryan
Houston
Old 02-09-2007, 09:17 PM
nucleus nucleus is offline
Default Overhead Entry, The missing piece
I have been trying to educate myself on the overhead entry, read all the threads, and then quized my naval trained instructor about it.
There seems to be amissing piece in the discussions here, and that is altitude. The overhead was designed to occupy minimal airspace at pattern altitude to minimize exposure to groundfire.
As I understand it, you shouldn't hit pattern altitude until you are over the numbers on your upwind entry.
Staying higher has obvous other advantages also.
Nucleus
Old 02-09-2007, 09:47 PM
N98HK N98HK is offline
The overhead pattern has nothing to do with avoiding ground fire. Its actually a pretty predictable way to get shot by a MANPAD. A high tactical initial, starting at least 4k' AGL, is intended to cool the motors and avoid the IR threat. Its almost like executing an SFO. A normal "military" pattern is about maximizing the number of aircraft in the pattern, and doing it safely. A controller is not even required to make this happen. The difference between the overhead that the military flies and what we attempt to do in GA is the training that EVERYONE has received. A military pattern is full of pilots who understand that when someone calls "initial", you can not pull closed traffic on the go without a potential conflict. What I'm trying to say is that priority and procedures in the pattern are understood by all pilots due to common training. Now, if you take a low time GA pilot, mix him up with some RV drivers flying unfamiliar procedures, you have all the ingredients for a mishap. Is flying over the field at pattern altitude on the "upwind" dangerous? NO!! Who else is flying there? Is there any potential conflict? The issue is that if you call "initial" or "in the break" will anyone understand what you are saying. The last thing you want to be is the D#$k who makes the student pilot curl up in a ball and feel that he has made a mistake because you want to be the cool guy leading a 4 ship to initial. As many others have said on other threads - there is a time and a place for everything.
Dave Halasi-Kun
RV-7 N98HK
