Old 02-06-2007, 10:48 AM
Bryan Wood's Avatar
Bryan Wood Bryan Wood is offline
Default No more position and hold
Well it's official. As of yesterday new FAA rules went into affect making "Position and hold" a thing of the past. Expect delays and hot engines while waiting for breaks so controllers can get you out. Bummer!
Bryan 9A Sold
Beech S35, and daydreams of a Super 8 or a Rocket starting to take over my brain.
Old 02-06-2007, 11:14 AM
AX-O's Avatar
AX-O AX-O is offline
Is that for all traffic? Or just civilian traffic? We use that a lot here in our airfield. Do you have a link?
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 02-06-2007, 11:23 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Have you got a web reference we can read Bryan?
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 02-06-2007, 11:31 AM
zilik's Avatar
zilik zilik is offline
VAF Moderator
Default Real Bummer
They yanked our postion and hold privs last year after a couple of incidents after the tower muffed up and had one on the runway and the plane on final cleared to land. It was not the pilots fault but the pilots get the brunt of it. Of course at a non-towered field you can still do it.
Gary
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993 SOLD
Old 02-06-2007, 11:32 AM
Bryan Wood's Avatar
No web link here. The reason I became aware of it is that being home with the flu and looking for things to keep from going crazy I called the tower at my local field Reid Hillview to ask a question that has been on my mind. Before hanging up I was told that the boss up there was working on briefing of sorts to put into the GA terminal to explain the new rule that disallows position and hold as of yesterday. I asked if it national and he said it is going into effect everywhere. He seemed disappointed by the rule stating that the procedure was a usefull tool for them to keep traffic flowing. I'm sure more will be coming out on it soon.
Best,
Bryan 9A Sold
Old 02-06-2007, 11:45 AM
RobW RobW is offline
Default TIPH
It applies to all airports, but each facility can put in for a waiver based on traffic and conditions. You will probably see that most places that need position and hold, will continue on as before.
Old 02-06-2007, 11:47 AM
the_other_dougreeves the_other_dougreeves is offline
I can't find anything in the Federal Register. Here is the most recent guidance I can find on changes to TIPH:
http://www.faa.gov/airports_airtraff.../N7110.456.pdf
These changes were effective yesterday.
An older version of 7110.65R without the new revisions can be found here:
http://www.faa.gov/regulations_polic...a/7110.65R.pdf
Below is the relevant section is 3.9.4, which I have marked up to incorporate the new language.
3−9−4. TAXI INTO POSITION AND HOLD (TIPH)
The intent of TIPH is to position aircraft for an imminent departure. Authorize an aircraft to taxi into position and hold, except as restricted in subparagraph g, when takeoff clearance cannot be issued because of traffic. Issue traffic information to any aircraft so authorized. Traffic information may be omitted when traffic is another aircraft which has landed on or is taking off the same runway and is clearly visible to the holding aircraft. Do not use conditional phrases such as ?behind landing traffic? or ?after the departing aircraft.?
b. USN NOT APPLICABLE. First state the runway number followed by the taxi into position clearance when more than one runway is active.
PHRASEOLOGY−
RUNWAY (number), POSITION AND HOLD.
Or, when only one runway is active:
POSITION AND HOLD.
c. Do not issue a clearance to an aircraft requesting a full-stop, touch-and-go, stop-and-go, option, or unrestricted low approach on the same runway with an aircraft that is holding in position, taxiing into position or has been cleared to taxi into position and hold until the aircraft in position starts takeoff roll. Do not clear an aircraft to TIPH if an aircraft has been cleared to land, touch-and-go, stop-and-go, option, or unrestricted low approach on the same runway.
PHRASEOLOGY ?
?RUNWAY (number), CONTINUE, TRAFFIC HOLDING IN POSITION.? or, (when only one runway is active): ?CONTINUE, TRAFFIC HOLDING IN POSITION.?
EXAMPLE ?
?American 528, runway two three, continue, traffic holding in position.? or, (when only one runway is active): ?American 528, continue, traffic holding in position.?
(1) Landing clearance need not be withheld if the safety logic system is operating in the full core alert runway configuration.
(2) Facilities without the safety logic system and facilities with the safety logic system in limited configuration must withhold landing clearance until the aircraft in position starts takeoff roll.
d. When an aircraft is authorized to taxi into position and hold, inform it of the closest traffic requesting a full-stop, touch-and-go, stop-and-go, option, or unrestricted low approach to the same runway.USAF. When an aircraft is authorized to taxi into takeoff position to hold, inform it of the closest traffic within 6 miles on final approach to the same runway. If the approaching aircraft is on a different frequency, inform it of the aircraft taxiing into position.
e. USAF. When an aircraft is authorized to taxi into takeoff position to hold, inform it of the closest traffic within 6 miles on final approach to the same runway. If the approaching aircraft is on a different frequency, inform it of the aircraft taxiing into position.
f. Do not authorize an aircraft to taxi into position and hold when the departure point is not visible from the tower, unless the aircraft?s position can be verified by ASDE or the runway is used for departures only.
g. An aircraft may be authorized to taxi into position and hold at an intersection between sunset and sunrise. The procedure must be approved by the appropriate Director, Terminal Operations (service area office), and by the Director, Terminal Safety and Operations Support, and must be contained in a facility directive. The following conditions must apply:
(1) The runway must be used as a departure-only runway.
(2) Only one aircraft at a time is permitted to taxi into position and hold on the same runway.
(3) Document on FAA Form 7230-4, Daily Record of Facility Operation, the following:
?TIPH at INT of RWY (number) and TWY (name) IN EFFECT? when using runway as a departure-only runway. ?TIPH at INT of RWY (number) and TWY (name) SUSPENDED? when runway is not used as a departure-only runway.
h. USN. Do not authorize an aircraft to taxi into position and hold at any time when the intersection is not visible from the tower.
i. Do not authorize aircraft to simultaneously taxi into position and hold on the same runway, between sunrise and sunset, unless the local assist/local monitor position is staffed.
j. USAF/USN. When issuing additional instructions or information to an aircraft holding in takeoff position, include instructions to continue holding or taxi off the runway, unless it is cleared for takeoff.
PHRASEOLOGY−
CONTINUE HOLDING,
or
TAXI OFF THE RUNWAY.
k. When aircraft are authorized to taxi into position and hold on runways that intersect, traffic must be exchanged between that aircraft and the aircraft that is authorized to position and hold, depart, or arrive to the intersecting runway(s).
EXAMPLE ?
?United Five, runway four, position and hold, traffic holding runway three-one.?
?Delta One, runway three-one, position and hold, traffic holding runway four.?
or, when issuing traffic information to an arrival aircraft and an aircraft that is holding on runway(s) that intersect(s):
?Delta One, runway four, position and hold, traffic landing runway three-one.?
?United Five, runway three-one, cleared to land. Traffic holding in position runway four.?
or, when issuing traffic information to a departing aircraft and an aircraft that is holding on runway(s) that intersect(s):
?Delta One, runway three-one, position and hold, traffic departing runway four.?
?United Five, runway four, cleared for takeoff, traffic holding runway three-one.?
l. When a local controller delivers or amends an ATC clearance to an aircraft waiting departure and that aircraft is holding short of a runway or is holding in position on a runway, an additional clearance shall be issued to prevent the possibility of the aircraft inadvertently taxiing onto the runway and/or beginning takeoff roll. In such cases, append one of the following ATC instructions as appropriate:
1. HOLD SHORT OF RUNWAY, or
2. HOLD IN POSITION.
m. USAF/USN. When issuing additional instructions or information to an ircraft holding in takeoff position, include instructions to continue holding or taxi off the runway, unless it is cleared for takeoff.
PHRASEOLOGY−
CONTINUE HOLDING,
or
Doug "The Other Doug Reeves" Reeves
CTSW N621CT - SOLD but not forgotten
Home Bases LBX, BZN
Last edited by the_other_dougreeves : 02-06-2007 at 12:05 PM. Reason: Update to effective date
Old 02-06-2007, 11:58 AM
Kahuna's Avatar
Kahuna Kahuna is offline
Our regional Atl airport, KLZU, busy single runway, stopped this quite some time ago and it means long lines and holds. Drives us all crazy. Thanks for letting us know that there is a waiver provision. Ill ask my tower about it.
Best,
Kahuna
6A, S8 ,
Gold Hill, NC25
hydroguy2's Avatar
Yep, No "position and hold" today at KHLN. I was up in the Citabria today, so was a Student pilot in a 172. A pilatus was stuck waiting for 2 others inbound, we got extended. all due to no position and hold option. The Tower guys told everyone to write a letter or make a phone call to complain. They don't like it either.
One positive though, I got several: "Left (or right)turn approved as soon as altitude and speed permit." Got to buzz the airport managers office on one trip. Another time I had the Tower inspect the belly of the citabria. Alos got to do short approach engine out from abeam the numbers. Grreat practice.
Old 02-06-2007, 12:11 PM
As I read the new language, the problem seems to be:
"Do not issue a clearance to an aircraft requesting a full-stop, touch-and-go, stop-and-go, option, or unrestricted low approach on the same runway with an aircraft that is holding in position, taxiing into position or has been cleared to taxi into position and hold until the aircraft in position starts takeoff roll. Do not clear an aircraft to TIPH if an aircraft has been cleared to land, touch-and-go, stop-and-go, option, or unrestricted low approach on the same runway."
This suggests to me that TIPH isn't banned, but you can't have an aircraft already cleared to land while someone gets TIPH or can't clear someone to land if someone is already TIPH. Am I reading this right?
I can't wait to try this out at ADS on a busy day
Home Bases LBX, BZN
