Old 05-30-2017, 07:19 AM
RV74ME RV74ME is offline
Default WD 409 tail spring weldment...paint or powdercoat?
About to fit the WD 409 piece between the F711/F712 bulkheads and started thinking about best way to protect it. Paint or powdercoat? What about the inside of the tube?
Steve T.
CFII/MEI/ATP 737,DC-10
RV-7 slow build
AUO
Old 05-30-2017, 08:25 AM
For the equivalent part on my RV-3B, I chose cadmium plating:
I don't care much for the durability of powdercoat and would have painted the exterior, if this weren't available.
Only the exterior was plated. The interior will be greased, probably, so that I can get the tailspring out again if it's ever necessary.
Dave
Old 05-30-2017, 09:01 AM
RV6_flyer's Avatar
I like paint better. Powder coat has been known to hide cracks and to crack making one think there is a crack where there is not.
IIRC, the inside where it touches the spring is ground to a precision fit. Not something that one would want dry paint on making the "stinger" not fit. 20+ years ago, I did what ever the manual said and used grease or did wet assembly with chromate.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 05-31-2017, 06:15 AM
Good tips, guys. Thanks!
Steve T.
RV-7 slow build
AUO
