Old 06-26-2017, 10:40 AM
RFSchaller RFSchaller is offline
Jim,
Your assumption that one pump failure will bring in the fuel pressure alarm is incorrect. I have been operating with a switched fuel pump for 5 years and see only a couple of tenths of a psi difference when I switch the electric pump on and off. As I said I just believe the scenario of losing the electric pump when the mechanical has failed is much worse than having to flip a switch in cruise if I experience vapor lock. Coupled with the operating experience of one vapor lock in 5 years (with old fuel) the approach I use seems sound.
A wise horse will check what's in the water and then decide whether to drink it.
Rich
Old 06-26-2017, 11:35 AM
DHeal DHeal is offline
Jim/Rich --
I agree that the loss of one of the two fuel pumps in-flight will likely not cause a "Yellow or Red" FP warning indication on the SV/Garmin and that the resultant loss in FP may be slight (in my RV-12, I do see a noticeable slight reduction in FP psi when I disable the electric pump in-flight) -- good points. I guess it all comes down to whether or not the pilot concurs with the benefits of Van's "full-time" electric pump use design philosophy versus a "use-it-when-you-want-it" philosophy. It is a question of whether or not one thinks the "full-time" electric pump will live a long and happy service life versus occasional switch-activated use. Suum Cuique
-- David
ps -- I will admit that I wonder how many cycles the FP fuse receptacle will tolerate over time since I remove/reinsert the FP fuse at least once every 28 days for data updates.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 940+ hours (as of September 2020)!
VAF donation through June 2021.
Old 06-26-2017, 06:24 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
What about scenario where you re-start a hot engine, perhaps in a hot climate, and do not switch electric fuel pump on until ready for flight... Suppose fuel has boiled in supply lines and maybe even carb float bowls because under-cowl temps are very high and fuel system is heat-soaked.
What if you take off and engine stumbles at this very critical phase of flight?
Jim Stricker
EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 622
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father & CFI) - USAAF 1st Lt. Captain B-17H
Old 06-26-2017, 08:14 PM
Jim,
I'm not saying that one should never use the electric fuel pump if it's on a switch. I certainly agree that if the pilot thinks vapor lock is a strong possibility it should be on. I am glad to have experienced it and seen the immediate benefit the electric pump provided when I turned it on. I now know what a vapor lock scenario looks like which is also useful.
Rich
