When running the boost pump (engine off), what was the throttle and mixture position?
Also not sure... When you describe that fuel is "pouring out"... Are the injectors installed for flight, or are you doing the flow check with the injectors removed?
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
