Old 06-17-2017, 02:09 PM
dlomheim dlomheim is offline
Default RV "Hitting a Wall"...
Originally Posted by N941WR View Post
A couple of thoughts on installing a BRS in an RV, any RV. "...The -9(A) can fly so slow, if you have a problem, trim it for best glide, and unless you hit a wall, you "should" be OK."
Even if you "hit a wall", you still might be okay! In mid-2000's an RV-6 hit a parked dump truck in a Dept. of California parking lot, yet both pilot and pax survived! Upon impact, their bodies were thrown forward which pulled on their shoulder straps and transferred the deceleration G load to the tail cone where the steel wires attach. This pulled the tail cones together, and when they got to the point where they couldn't do that any more, the double row of rivets (that attach the baggage area fwd fuselage to the tail cone), all sheared off! This then allowed the tail cone to slide forward, and both pilot and pax received deep lacerations when their heads hit the metal front edge of the instrument panel cover; but they did thankfully survive. Just shows how important it is to properly control the aircraft all the way to the flare, and not allow it to hit hard which is never good on internal organs!
Doug Lomheim
RV-9A Mazda 13B/FWF
RV-3A sold
Old 06-17-2017, 07:29 PM
Steve Melton's Avatar
thread drift. the glare shield edge should make us aware of danger. this may not be the final solution but it may help. a hard round shape. an idea stolen from Kevin Horton.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
Old 06-19-2017, 10:48 AM
Default Instrument Panel Edge Cover
Very nice!
Doug
Old 06-19-2017, 04:39 PM
RV9A Bill RV9A Bill is offline
Default RV 9A brs
Aero classic makes an excellent cushioned edge for the instrument panel edge. I installed one. Very easy. Looks good.
RV9A Bill
RV9A 789BT flying
Old 06-19-2017, 04:54 PM
Coming back to the idea of a parachute, this video, showing the ground test of the BRS installed in the Glasair Sportsman, gives an idea of the energy involved in firing the parachute rocket.
https://www.youtube.com/watch?v=6NQRYkIcj4c
Old 06-25-2018, 08:36 PM
nickj02 nickj02 is offline
Default BRS
Check out the June issue of kitplanes...there is an article about my install on an RV-9A along with some weight and balance sheets.
Old 08-20-2018, 07:49 PM
musicmanager musicmanager is offline
I am building a 7A with a chute, should be flying this week. I have a IO390 so not too worried about the extra weight in the back. Hit my up with questions.
Old 09-09-2018, 07:35 PM
tfoster100's Avatar
tfoster100 tfoster100 is offline
Default Kitplanes article
Read the article in Kitplanes. Looks and sounds very good. Nice to have this as an option as more spouses that aren?t pilots can attest to. My wife is a bit nervous if anything ever happened to me and she has to try to land it.
Tim Foster
Dues paid thru 2020
Building RV-14a kit # 140381
Finish kit in process
182 Sold 😂
https://eaabuilderslog.org/?s=tfoster
Old 09-10-2018, 09:29 AM
rvbuilder2002's Avatar
Ok.....
What is the overall empty weight?
Scott McDaniels
Hubbard, Oregon
Old 01-27-2019, 08:45 AM
Mancival Mancival is offline
1 year ago I installed a 140 sqm Galaxy parachute in my RV7A. So far I flew 80h (including 6g aerobatics) with no issues. Externally the plane is no different from any other rv7a, which, along with CG balance, was the main reason NOT to go for the BRS kit (I even met in person BRS CEO to convince him to change his design before deciding to invent one myself!). I designed the installation myself with the help of Galaxy CEO who flew over to physically witness the installation. The installation is just behind the firewall, on the passenger side. It deploys upward in front of the windshield. The 4 main cables are attached: 2 to the engine mount, and 2 to the rear spar. To reach the rear spar they come out from the plastic engine cowl from the bottom and immediately enter the front part of the wing root fairing. These 4 cables are made of steel, to withstand an engine fire.
A picture of the installation (that's all is visible as difference with any other RV7A):
https://photos.app.goo.gl/xeaSMKYjBwfUjBcG6
Ideally it should deploy like this:
https://youtu.be/xwZrtYgnP7s
