Old 05-23-2017, 08:07 AM
istrumit's Avatar
istrumit istrumit is offline
Default Which bolt to use ?
For improved CHT, I am going to add a couple of AN960-10 washers to the baffle on #5 of my -10.
Does anyone know the model/description of the bolt I need ? Currently there is no bolt in that location.
Thank you,
Scott
Scott Martin
N430WP RV-10 - Purchased
Old 05-23-2017, 10:30 AM
clutch22 clutch22 is offline
This one? MS35206-265
Andrew Austin
RV-10
-Flying!
Old 05-23-2017, 11:54 AM
istrumit's Avatar
Yes...thats the one.
Scott Martin
Old 05-23-2017, 11:57 AM
jrs14855 jrs14855 is offline
Default Bolt
Hardware store allen head stainless screw should work on any of the parallel valve cylinders.
