Yeah, mine was rubbing. I finally noticed that one of the spring hooks was facing into the push rod at the servo and making contact with the tube. I turned it around and that fixed that issue, but I'm pretty certain I'm still touching out at where the spring connects to the push rod. At this location there isn't much movement between the spring and tube except for the stretching of the spring, so it isn't very noticeable.
I have a new access cover on order from Van's. I'm going to see if it will be possible to slightly move my servo aft. Maybe .063" will make a difference for me...
Andrew Austin
RV-10
-Flying!
