Old 05-17-2017, 08:45 PM
mbauer mbauer is offline
Default Questions About Sealing Tip-Up For Weather
I did not build my RV-6, bought it recently already flying.
I have a few questions about sealing the tip-up when it is closed. But first the status of why I'm asking the question to begin with.
My RV has several layers of a clear tape along the fuselage rails and the lip where the back of the canopy sits on the roll bar. These layers of tape are no longer stuck to the top of the fuselage. They are coming loose in long strips.
Build up was probably 1/16" to 3/32" thick, judging from the layers used.
Not sure what kind of tape it is, but it looks like it was used to seal the canopy when closed to keep the wind noise and rain out.
Is it possible to use normal weather stripping to seal the canopy?
I've read not to use electrical tape on the canopy as it can cause damage. Will the weather stripping also do this?
What other kind of issues am I asking for?
What could the clear tape be, is it something recommended for/by Vans?
The present tape doesn't look like any clear packaging tape or a scotch type tape.
What is the normal procedure for sealing the canopy?
Any help will be appreciated.
I fly down to KBOI to pick it up next week for the flight back to Alaska.
Thank you in advance for any help/advice provided!
Mike Bauer
N999SN 1998 Syd Nelson RV-6 (purchased 2017)
UTC -09:00 Alaska
Old 05-17-2017, 08:56 PM
Mike, let me know when you are coming in. I will be home next week except for Monday. I can help if you need anything and have most any tool you would need.
As far as electrical tape, that is the standard to use on the canopy because it is thick and comes off well. I would stay away from any duct or clear package tape.
I don't see why weatherstripping wouldn't work to close the canopy on. I only know about a tip up on my 9, but figure the 6 would be about the same. I have a friend with a 6 and will check.
Hope to see you next week.
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 05-17-2017, 09:39 PM
lr172 lr172 is offline
I have full weatherstripping on the bottom of the side canopy rails. I used the hollow D shape. You will pick the thickness that will seal your particular plane. You may need different thicknesses along the runs, depending upon how your builder worked this area. I also have weatherstripping on the forward upper skin area where they have you install an angle to hold it. I also have a form fitted targa strip that seal the whole area where the two canopy sections meet, all the way down past the fuse rail. They are no more difficult to add post build. You can research these here on this site. Between the two of these, I have NO air or watter coming in from the canopy area. I fly down to about 0*, so cannot afford to have any cold air working against the barely adequate heaters. Note: preventing water ingress on the forward skin is a more involved discussion.
Note: I used flange bushings and bolt stand-offs at the rear to hold the canopy in a fixed, repeatable position, horizontal and vertical, when closed. This keeps the targa strip tightly held to the rear canopy section and eliminates any chaffing wear.
Larry
Old 05-17-2017, 09:45 PM
Thank you for the offer! PM sent.
Mike Bauer
UTC -09:00 Alaska
Old 05-17-2017, 09:47 PM
Originally Posted by lr172 View Post
I have full weatherstripping on the bottom of the side canopy rails. I used the hollow D shape. You will pick the thickness that will seal your particular plane. You may need different thicknesses along the runs, depending upon how your builder worked this area. I also have weatherstripping on the forward upper skin area where they have you install an angle to hold it. I also have a form fitted targa strip that seal the whole area where the two canopy sections meet, all the way down past the fuse rail. They are no more difficult to add post build. You can research these here on this site. Between the two of these, I have NO air or watter coming in from the canopy area. Note: preventing water ingress on the forward skin is a more involved discussion.
Thank you! Was wondering what will work to seal the top of the canopy.
I did do some searching, mostly in the Tip Up Vs Sliding threads. Didn't see anything there yet...Still reading.
Mike Bauer
UTC -09:00 Alaska
Old 05-17-2017, 10:18 PM
search Targa. There are some good, descriptive threads with pics. Brantel had a good one.
Old 05-17-2017, 10:19 PM
You can probably seal it up with intelligent and creative use of weatherstripping. I liked the look of the targa and thought it would be the most effective sealing method. It is more work though. Either way, you can do better than packing tape.
Larry
Old 05-17-2017, 10:40 PM
Larry
Hi Larry,
Thank you for the search word "Targa".
Found a couple of great photos showing what it is. Will be the best answer for the RV to survive here in Alaska. Will work out a plan to modify it once it is back.
For now will try the weather stripping for the flight back, unless there is a reason not to.
Mike Bauer
UTC -09:00 Alaska
Old 05-18-2017, 07:29 AM
Hi Larry,
Good luck. Some builders have only bonded the strip to the plexi and a couple have come off in flight. Be sure to use a handful of blind rivets to keep the strip secure in case the adhesive fails.
Old 05-18-2017, 07:52 AM
Flying again!'s Avatar
Flying again! Flying again! is offline
Default Ask Vlad
Vlad keeps his 9A outside year round with ice, snow etc. and flies everywhere!
He should be able to chime in on how to seal a tip-up
RV-10 N331JH 3rd owner (First flew in 2005, #15 flying)
Northwest Regional 52F
