02-04-2007, 09:05 AM
FF-714 alternator support strut sanity check
Hi everyone,
I was just checking over the FWF kit directions yesterday to make sure I did everything. I found this bit: "Make the FF-714 alternator support strut shown on the alternator installation drawing. Adjust the hole spacing to fit your installation. The strut requires a slight joggle. Use a big bench vise and a big hammer..."
So I don't have the Van's alternator nor the alternator drawing, as I have a B&C 40 amp. I would assume this the same thing as the "tensioning arm" referred to elsewhere in the instructions, but it talks about "hole spacing" so I'm not so sure. The tensioning arm I'm thinking of has a big long slot and you put the metric bolt through it into the alternator. This thing:
02-04-2007, 09:12 AM
Banned
Alternator
Looks good! Maybe a wide area washer would give you better contact under the tension adjust bolt.
02-04-2007, 09:14 AM
Banned
Overtorque
Also be careful not to over-torque. Alternator threads are aluminum.
02-04-2007, 09:27 AM
I believe the joggled bracket the instructions refer to is the one that goes between the forward alternator pivot and the starter motor. I assume that it helps keep both alternator pivot bolts acting in double shear. See picture below from my recent installation.
Jim Sharkey
RV6 Tip Up O360-A1A VFR
Fitting Cowl etc
02-04-2007, 09:38 AM
Yes, that might be it! The tech counselor also mentioned having seen a bracket like this.
Hmm, that pivot bolt is one long bolt on mine -- will probably be too short if I insert another thing in there.
Are other B&C 40 amp users installing this bracket?
02-04-2007, 08:39 PM
Alternator Support Bracket
There are probably various support bracket designs depending on the alternator. For my installation, stock Van's 40 amp on an O360-A1A, a joggle or spacer is required. I had a bracket failure at about 450 hours because I didn't get the bracket in perfect alignment as can be seen. The offset in my case is about 3/8 s of an inch.
[IMG]  [/IMG] [IMG]  [/IMG]
Frank M
RV8 500 Hrs Sold
RV4 300 Hrs Sold
RV3(B) Sold
RV4 Refreshing engine
02-04-2007, 09:07 PM
I have the B&C 40-amp alternator as well. I am not flying yet, but I can hardly believe that a joggle bar is necessary. The alternator came with a mounting bracket and the slide-adjustmetn shown i the picture in the previous post. I installed it with the supplied hardware, and it sure seems snug as a bug to me. I gotta believe that joggle bar is for the van's supplied alternator. Somebody stop me if they have good hard info to the contrary.
erich weaver
02-05-2007, 11:16 AM
Break sharp edges
ALL you guys make sure the bracket does not have sharp edges or burrs. By all means get some fine sand paper/de0burr tool and round those sharp edges on the tension arm.
Also when you wrap safety wire around the tension arm, it can wear a grove and make a stress riser and cause a crack.
Well I noticed that many are safety wiring the bolt head.
Is there a better way? I don't use safety wire on that bolt. The problem is that you are threading into the alternator.
I used a threaded bolt that goes thru the alternator threaded lug and protrudes enough to add a nut. The nut with a lock washer and optional cotter pin adds my security.
On the bolt head side/tension arm side, a flat washer and star washer. Don't use a lock washer against the tension arm because it leaves marks which can cause cracks.
With the torque and double nut method (the threads in the alternator and nut) the chance of it coming loose is reduced to an acceptable level.
You can always drill out the threads on the alternator and use two lock nuts. As some one pointed out the aluminum can strip and that is a good reason to use steel nuts.
If you do safety wire the bolt, try to not wrap it around the tension arm. Possibly you can add a tab (riveted on) to attach the safety wire.
Click
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
02-05-2007, 11:41 AM
The B&C arm (at least) is steel, do you really think it would crack from a safety wire dent?
02-05-2007, 12:18 PM
Good point, I do think so
Yea. Vibration will wear a small notch and combo of stress, vibration, possible crack. I have seen so many cracks in steel tension arms you have to take notice:
Stress concentration: Burrs, nicks, sharp edges
Pre-stress: mis-alignment, clamp up bending
High stress: At the end of the slot you really don't have a solid bar X thick by Y wide. You have two tiny little thin strips separated by a wide slot. This puts those strips in bending, not really working together. Now add the stress risers, radius, stress concentration and vibration, yea I think it makes a difference. Steel is stronger, but it does not have great crack growth properties. WHO knows what some of these parts are made of.
My tension arm is steel (what heat treat I don't know), has a joggle bent into it for alignment and it way thicker than a generic 1960's chevy tension arm. It also looks thicker than than B&C from the picture. It's from a Niagara Airparts alternator kit. I noticed the edges where sharp and deburred them. Really that is standard procedure, right, nothing special.
I am not using any safety wire and counting on the lock feature of washers and "jam nut".
Not saying it is right or safety wire grooves are bad or going to cause cracks, just a thought. I do think any notch or "dent" should be avoided as much as loose bolts and nuts, but that is just me.
Really the whole tension arm affair is 1950's car stuff. The geometry, design of the tension arm, lack of positive bolt retention (place to safety wire) make it not "aircraft" quality. Clearly its a weak area, so every little bit helps.
One problem, you can't torque the bolt up in the aluminum alternator housing. Torque (friction) is a VERY good way to keep things put. Go to GE or P&W jet engine factory. They don't put safety wire on anything because it just can't be installed. So they use super strong bolts and torque them heck for stout.
Just different ideas. Good point. Short answer, I don't know but I respect that tension arm and want to baby it. I see more cracks than loose bolts.
I am not anti-safety wire but what about Loctite and tabs. You could bend up a little aluminum tab to cradle around the tension arm with tabs to keep the bolt from turning. You could make a batch and replace them every time you take the alternator off, which should be rare. I just think the way the safety wire looks is kind of marginal. It is a tough place to deal with and respect not having bolts come loose but is it really needed? Can you do something else? Each to his or her own.
George
Raleigh, NC Area
2020 Dues Paid
