The physical dimensions of the tack drive on the back of the 4 and 6 cyl engines is the same.
They both drive off of the aft end of the cam shaft.
I believe the cam shaft rotation is the same ratio for both engines.
Therefore, I think it should work for both engines (4 and 6 cyl.).
Scott McDaniels
Hubbard, Oregon
