Old 05-07-2017, 06:29 AM
trib trib is offline
Default GPS cable routing
I'm installing a Stratus ESG to replace my KT=76A transponder and get ADS-B out. I already have my GPS antenna for the Garmin 300 XL under my cowling and don't have the room to give the required 1' distance between the two antennas. I was thinking of installing the second GPS antenna in the wingtip. Can I run the cable in the tube with the strobe/nav light wiring or would this affect the signal? I don't know how sensitive the GPS antenna is and am looking for advice.
Tim Ribble
Virginia Beach
RV-6A (only took 13 years to build )
N621TR In unrestricted operation
Old 05-07-2017, 07:35 AM
f14av8r's Avatar
f14av8r f14av8r is offline
Default Turtleback?
Hi Tim,
Why not put the ESG antenna on the turtleback. That's what my buddy did with his install in a -7A.
Randy King
Tampa (Wimauma), Florida
RV-4 N212CS (sold)
RV-8 N184RK (flying)
Flying an A320 to pay the bills
Exempt and gladly donating anyway - Current through March 2021
Old 05-07-2017, 11:31 AM
I like to keep things hidden if I can. The antennas work fine if under glass.
Tim Ribble
Virginia Beach
Old 05-07-2017, 04:49 PM
RV7A Flyer's Avatar
Before doing all that, you might try the simple route of putting the Stratus GPS antenna under the cowl, too.
FWIW, I have both my 430W and my Skyview WAAS antennae under the cowl (in fact, on the same tray next to each other), and have had zero problems with either instrument.
Old 05-08-2017, 09:02 AM
airguy's Avatar
airguy airguy is offline
Same here, actually touching each other in the tray. No problems as long as they are both receivers - if you have a transmitter in close proximity then that's another story.
Old 05-11-2017, 02:25 PM
Okay, I'll go ahead and try them together in under the cowling. I like that approach better anyway.
Tim Ribble
Virginia Beach
Old 05-11-2017, 03:11 PM
Sam Buchanan's Avatar
been here awhile
Yep, like my Stratus ESG but the antenna is one honkin' big lump. The only flat area on the top of the RV-6 fuse is the deck in front of the canopy (ugh...). My antenna went inside the cowl, too. I have two small GPS antennae next to each other on the glare shield and they play nice.
Sam Buchanan
RV-6
Fokker D.VII replica
