  #21
Old 05-03-2017, 03:26 PM
vic syracuse vic syracuse is offline
Super Moderator
Vic, got a link? Found these two (both appear to be voltage monitoring)...
http://lightspeed-aero.com/Manuals/PS_Diagram.htm
http://lightspeed-aero.com/Images/du...ator-LSEr4.pdf
...but nothing to test battery capacity.
Re voltage monitoring, these are less than $5 delivered, and can be configured to alarm:
http://www.vansairforce.com/communit...&postcount=166
Look at the dual power supply wiring diagram. By pulling the 10 amp breaker and putting the B ignition to the aux source, and watching the voltmeter, you should be able to test the aux battery. You could even run it in flight that way every once in a while.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 05-03-2017, 03:42 PM
Aggie78 Aggie78 is offline
Originally Posted by AlexPeterson View Post
Good point - I do check the voltage of this battery prior to startup before every flight. I also full time monitor its voltage during flight to be sure the proper charging voltage is being applied. The test I do annually is a capacity check, where I run it down to perhaps 10 volts, to determine amp-hr capacity.
Here's a method of very accurately determining battery capacity I used in when I was heavy into glider flying:
http://aviation.derosaweb.net/batter...ingFeb2012.pdf
I flew with 2 identical SLA batteries, and this load test was a great way of discovering one that was starting to decline.
Very important in a glider (with all the electronic gizmos nowadays) that doesn't have a non-electric variometer...
Rob Schroer
RV-7/N75WV
YIO-360-M1B
New Braunfels, Texas (KBAZ)
VAF Monthly Donor
Old 05-03-2017, 05:58 PM
DanH's Avatar
DanH DanH is offline
Ah, voltage monitoring over an extended time. That works. I was hoping he had some sort of interesting capacity test circuit....sorta like a standard automotive resistance load tester, or the test rig in the article Rob linked.
Dan Horton
RV-8 SS
Barrett IO-390
