  #11
Old 05-02-2017, 08:05 PM
rapid_ascent rapid_ascent is offline
Lots of stories on VAF about failed alternators. Batteries are a maintanence item that can have a low probability of failure if properly maintained. I plan a dual alternator system. I may have a small secondary battery too but my first line of defense is the backup alternator.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 05-02-2017, 08:43 PM
Bevan Bevan is offline
Batteries degrade (fail) slowly over time in that they store less useable energy, and yet we still fly with them never really knowing their capacity at that particular time.
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 05-02-2017, 09:34 PM
AlexPeterson's Avatar
Default two alternators vs two batteries
It also depends also on the type of ignition one has. I have dual lightspeed ignitions, so I prefer two batteries. I have a setup to test the backup battery (whose only function is to feed the second ignition) using a 12v lamp. This draws a known current, so I can calculate the effective amp-hrs available until it drops to some specific voltage. I test it annually.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 05-03-2017, 05:26 AM
DanH's Avatar
DanH DanH is offline
There is no one answer.
I entirely agree with the dual alternator strategy for an IFR bird, and lean toward dual alt/dual battery for EFI/EI.
That said, the KIS approach to VFR with a low-draw (<1 amp) electronic ignition is a small secondary battery. KIS is good.
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-03-2017, 05:37 AM
vic syracuse vic syracuse is offline
Super Moderator
For those with dual electronic ignitions I would encourage you to check the backup battery as often as possible, certainly more than once per year. I have seen more than one airplane come through my shop with the backup battery reading 5 volts! Sometimes it was due to a charging system failure and sometimes it was a corroded connector on the battery. Klaus has a schematic that allows you to test the backup battery prior to takeoff.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 05-03-2017, 07:10 AM
Vic
Good point - I do check the voltage of this battery prior to startup before every flight. I also full time monitor its voltage during flight to be sure the proper charging voltage is being applied. The test I do annually is a capacity check, where I run it down to perhaps 10 volts, to determine amp-hr capacity.
Alex Peterson
KADC, Wadena, MN
Old 05-03-2017, 07:16 AM
Veetail88's Avatar
Veetail88 Veetail88 is offline
You should check with Rosie about this, but read his Carribean trip thread first!
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 05-03-2017, 10:19 AM
JHartline JHartline is offline
Default Thank you all for the replies
I feel like the available backup-battery solutions are getting better but maybe not the ideal situation for me just yet. And the points about how to avoid getting stranded somewhere are well made. While my mission won't take me into austere locations we have all seen how deserted ramps are late on a weekend evening when we're trying to get home.
I will be talking with Stein very soon and I'm sure he will provide some great options to consider. Thanks for the input - it is always valuable and always appreciated.
James Hartline
Carrollton, GA 5GA2
RV-14 - First flight 4/7/2019. Phase I complete as of 9/11/2019!!
Old 05-03-2017, 11:43 AM
Super Moderator
Default Well done
Well done!
Vic
Vic Syracuse
Old 05-03-2017, 02:44 PM
DanH's Avatar
Vic, got a link? Found these two (both appear to be voltage monitoring)...
http://lightspeed-aero.com/Manuals/PS_Diagram.htm
http://lightspeed-aero.com/Images/du...ator-LSEr4.pdf
...but nothing to test battery capacity.
Re voltage monitoring, these are less than $5 delivered, and can be configured to alarm:
http://www.vansairforce.com/communit...&postcount=166
Dan Horton
RV-8 SS
Barrett IO-390
