Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 05-02-2017, 06:43 AM
N941WR's Avatar
N941WR N941WR is offline
Default Do McCauley props fit?
It is rare that someone mentioned McCauley props.
Do the hubs and spinners fit a standard RV cowl or are they larger than the more commonly mentioned Hartzell?
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 05-02-2017, 07:19 AM
BillL BillL is offline
Bill, you might just give whirlwind (ohio) a call. Their CS props use a "McCauley" hub, what ever that means. They have a machining center to make their hubs. A short discussion might get you what you want - prop flange, distance from flange to blade center etc. Best case is that you could use their backplate and spinner on a refurbished hub with blades of your choice.
Bill
RV-7
Lord Kelvin:
